old engine?
/ old engine? #1
boltz
Ontario Canada
kioti ck30, allis d-17, Cub Cadet Enforcer Zero Turn Mower
012.JPG I found this engine in the bush above our house. I don't know what it is from but if anyone out there does and is interested in it please let me know. Thanks, Doug Oct 9, 5.20pm. Will this picture now work? Thx for your patience. If ok have more pictures :)
/ old engine? #2
Pictures didn't open and it would help to fill out your profile so we could see where you live.
/ old engine? #3
Try the pictures again.
/ old engine?
Sorry, profile filled out now. Had wife post pictures, cause just learning, old guy here. Will try again over weekend when wife back home. Thx for your response. Also what are small segmented copper windings that are mounted individually all the way around ,at the flywheel end? Never seen anything like that before. Mind you you never taken a tractor apart either.
/ old engine? #5
I'm going to guess-------a old allis wide front end.
/ old engine? #6
Welcome to TBN.
Whatever it is, it's scrap.
/ old engine? #7
Welcome to TBN.
REALLY???
I would think that the block would be fine for somebody looking to replace a freeze cracked block, whose crank, head and pistons were still intact. If it is an Allis (and no it doesn't look like any of my Allis Chalmers engines) then there is a good chance it has replaceable sleeves also. Throwing out good antique parts just to make a dollar on scrap is not what is continuing the restoration of antique tractors.
My suggestion, find out exactly what it is, for sure... and find somebody who needs it rather than sending it to China.
David from jax
/ old engine?
Yep, that was my thinking, maybe useful to someone. Have side cover and part of water pump and fan blades. Still curious as to what windings are for? Was cleaning out some scrap metal before winter, so decided to post and see what you kind fellows has to say about it. Also found what I think is front end part of steering for Ford A or model T. Thx.
/ old engine? #9
I imagine the windings are for the magneto, kind of like a alternator on your car. There is probably a magnet on the flywheel to generate current. I think it would take some powerful wantings to think about any kind of use for it.
/ old engine? #11
The engine is out of a Fordson tractor,Thats the mag on the back of the flywheel, Believe a Model F best I can tell from pic.
/ old engine? #13
Fordson , Agree
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2716SFL (A61567)
2716SFL (A61567)
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
