Old Deere 310A
   / Old Deere 310A #1
rongrzywacz
PA - Lycoming co.
ford 2N
I purchased property that had an old Deere 310A backhoe on it. (Late 80’s, early 90’s) It hasn’t run in about 12 yrs . After some work on injector pump I managed to get it started.. everything seemed to work, will need a lot of TLC. The engine sounded fine… only major issue I saw was the clutch was slipping som going up hill…
Could the slipping be because of rust on the pressure plate…. If not how hard of a job is it to replace the clutch. Cost?? I don’t want to invest too much money or time in that old of a machine..
   / Old Deere 310A #2
Does clutch pedal have any free travel before throw-out brg is touched? Does this tractor have a hyd reverser? If so I suggest to change hyd filters & clean hyd oil suction screen(item 30).
   / Old Deere 310A
There is some free play in clutch, hard to tell if it’s worn linkag. How do I know if it has a hydraulic reverser?
It seemed to run ok on flat ground but was slipping going up hill
   / Old Deere 310A #4
If there is a handle on LH side of steering wheel that is control for hyd reverser. One can check pressure on control valve on RH side of clutch housing.
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2014 Freightliner M2 106 24FT Reefer Box Truck (A59230)
2014 Freightliner...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
