Old Cast Iron Cookware
   / Old Cast Iron Cookware #31
Thanks for this thread everyone. I learned a lot and it's reminded me of the cast iron skillets we used when we was just a younguns. I have officially been inspired to get some cast iron cookware. Yum yum yum:licking:
   / Old Cast Iron Cookware #32
Anything I've seen at auction around here goes for near new prices if not more. It takes time and effort to get a good seasoning on a cast iron pot. People know that and will pay a little for it.
A few years ago, we could still get nice cast iron pretty cheap at auctions, too, but I think the word has gotten out. I've seen things that appeared too far gone to use for anything but decoration go for new prices. Makes me glad I bought what we have when we did.
GGB
   / Old Cast Iron Cookware #33
I haven't been here since last year, but drop by to read once in awhile.
I have a couple of old cast iron skillets I cook in. These came from my great aunt, they were seasoned on an old cookstove, I swear they still have that flavor in them.
I agree with the one poster that said lard is the best to season with. When mine start to stick a bit I cook bacon in them, the wide slab stuff. Sadly bacon has more water in it, didn't use to do that but does have now.
Also did you know that a bit of iron comes off in the food and helps women to not be anemic? Read that long ago. I would imagine it would be good for the whole family.
   / Old Cast Iron Cookware #34
You guys seem to know the value of cast iron cook ware, what about your other half? Will your wife take the time to cook the old way? With all the new gadgets on TV why go to all the trouble when you can set it and forget it.
   / Old Cast Iron Cookware #35
My wife won't use anything else.
   / Old Cast Iron Cookware #36
Here is achapler from my book that I hand out when I teach a class on dutch oven cooking! :D
What is seasoning?
Seasoning is the method of preparing the cast-iron cookware for use. Seasoning is an easy but very important first step when using cast-iron. When we season a cast-iron pot, you are preventing rust and providing the cookware with a natural nonstick surface. The surface of cast iron is very porous, like a very fine sponge. The idea of seasoning is to fill all the fine holes with cooking oil, and then to convert that oil, to carbon, with heat. The carbon will eventually fill up all the fine holes and create that natural, renewable semi-permanent nonstick cooking surface. Unlike synthetically coated cookware, cast-iron can be seasoned, re-seasoned, and its cooking surface restored. Remember: Seasoning takes some time and use before a pan develops the shiny, black surface like your grandmother痴 cast-iron cookware. A black, shiny skillet or pot is a well-seasoned skillet or Dutch oven.
Seasoning, Curing, or Oiling your Cast Iron Dutch oven
Never Season your Dutch oven inside (at least while you wife is at home) because of the smoke, smell, and if you go real heavy on the grease or oil, there is a slight possibility of a fire!!!
All Dutch Ovens have a protective edible wax coating to prevent rust while shipping except the old used ones and it is long gone by now!.. To get rid of this material, remove any paper labels and wash the oven with hot, slightly soapy water and elbow grease. Note, always add the soap to the water not the water to the soap! It won't be so obvious that you washed anything off, but you did. Thoroughly rinse all the slightly soapy water out, and towel dry. Now place the Dutch oven upside down, and lid right side up on a heat source, (BBQ grill, outdoor smoker, or indoor oven, remember WIFE BE GONE), at a temperature of 500+ degrees to burn off the wax and be sure to place an edged cookie sheet, or foil on the shelf underneath to catch the drippings... This will remove the protective wax coating. Now allow it to completely cool down. Wash with plain water and dry thoroughly to eliminate any deposits. You can put a light coating of oil on the oven even before it becomes dry. Cast iron is very sensitive to changes in temperature, making it an excellent cooking material, but also making it susceptible to rust if not properly cared for. The oven must be seasoned immediately, or it will start to rust right before your eyes.
The following procedure can be done in your kitchen oven at home. You might want to be sure the vent fans are on, and maybe open a kitchen window or two, cause the carbonizing oil might create an odor in the house. Place the Dutch oven in the oven and when they are just too hot to touch with the bare hand, remove from the heat using gloves. Thoroughly coat them inside and out, the legs, lid, and top handle (even the bottom) with solid Crisco or a vegetable oil. Use a paper towel or a natural fiber brush, not plastic, cause it will melt. Doing this is messy, so do it on some newspapers. Let them cool about 30 minutes, and then wipe the excess Crisco out with a paper towel. The heating process dries the cast iron and also drives out air from the small pores. When coated while hot, and then allowed to cool, the oil gets drawn into these pores.
Lightly grease the inside and outside of the pot and lid including the handles and legs with solid Crisco or a vegetable oil, one that offers a low burning point.
Note if you plan on cooking for groups you might want to stay away from allergenic type oils like peanut oil, ect.
You do not want the oil to pool anywhere while you are seasoning your oven, so be sure to turn the pots bottom, upside down and the lid, right side up. You might put the Dutch oven in upside down, and then put the lid on the top of the legs. Be sure the cookie sheet or foil is still on the shelf underneath to catch the drippings. You want the heat to go to around 400 to 425 degrees to heat the oil. You will notice that sometime/all times during this process, a slight smoke will come out for about 20 minutes or so. This is normal. Remember, you are carbonizing the oil into the pan. That is what creates the nice black look that you want. Your Dutch oven will be extremely hot!!! After 1 ス hours, just turn the heat off and let the Dutch oven cool inside the oven by itself. This will take some time. I just let mine sit overnight, and that way it is cool in the morning when I take it out. Your oven should be a nice black color. If you get what I call dappling, this is from not removing all of the protective coating before seasoning your Dutch oven. All you need to do is re-scrub those areas and then re-season your Dutch oven. If it is a brown or bronze color, then you need the temperature higher, and/or a longer time cooking. If the pans are not as black as you like, just put on another light coat of oil and repeat the heating process on a little higher heat. Remember, you want your Dutch Ovens black not brown.....brown means that you need to season at a higher heat. I also do mine several times anyway.
When you are done you're ready to cook.
Sometimes acid foods such as chill, spaghetti, or tomato sauces might remove some of the seasoning. So, if your food tastes like metal, your oven needs to be re-seasoned. I just give it a good washing, lightly oil, place it upside down in an oven, and do a mini re-season.
If you have Rust
If a pot gets rusty and the rust is not too bad, even pots that have been used for flower pots can usually be rescued! Scrub the pot and lid with a scouring pad several times and rinse well. Put over a low heat source to dry out all the moisture. While lightly oiling the pot pay particular attention to the inside of the lid and pot. With a white paper towel keep applying a light coat of oil, wipe it out until the towels are coming out oily, but clean. I would then fill the pot with water and about a cup of vinegar and bring it to a rolling boil. Then repeat the white paper towel and oil process over again. When the paper towels come out clean, then re-season as if it痴 a new pot.
If the pot has got paint, or 200 years of burnt on crud, don稚 panic! Just put it in your self-cleaning oven or any oven and bring it to the highest setting, at least 500+ degrees or higher for at least 3 or more hrs. Everything on it will become ash, after letting it cool down in the oven, usually over night. Then use a wire brush on it and then treat it as a normal rusted pot.
CAUTION Remember to always use the proper tools and hot pads to do the seasoning since the pots hold their heat. Never touch a hot Dutch oven without good hot pads. This also works for the tools!!!
   / Old Cast Iron Cookware #37
Reading this thread has given me a whole new understanding and appreciation of cast iron cooking things.
It now bothers me to see all the bargains I let go at farm auctions.
I have now relegated to the back of the cubboard are all the other pans I used to think were better than they are.
I knew they weren't heating correctly but I just sort of passively accepted it.
In retrospect, I wonder what I was thinking.
   / Old Cast Iron Cookware #38
Reading this thread has given me a whole new understanding and appreciation of cast iron cooking things./QUOTE]
Put a properly stoked wood/coal cookstove under that cast iron and you could be in cooking heat control heaven. :thumbsup:
   / Old Cast Iron Cookware #39
When we lived in Maine we cooked over a modern Oval and Sweetheart stove---sometimes a Defiant and it was a wonderful experience.
Airtight kept the wood burning more evenly and the beautiful cast soves radiated much more than the traditional warmth.
Some of my best napping was in front of that kitchen Oval stove.
We raised it higher with a firebrick under each leg to make it easier to load and discovered the unintended consequence that the puppies
could fit under the oven space to keep warm. Puppies got so hot you could hardly touch them. Really cute too.
Incidentially, I rented an apartment in the early 1970's that had a cookbook in the kitchen as a decoration.
It was one of the earliest of "The Joy of Cooking " books and I recall that an entire chapter was devoted to properly builing a woodstove fire and maintaining constant heat.
   / Old Cast Iron Cookware #40
...I rented an apartment in the early 1970's that had a cookbook in the kitchen as a decoration.
We inherited an old pressure cooker from my wife's grandmother. The manual that came with it devoted a few pages to the merits of pressure cooking including the savings on charcoal and wood. There were also a few pages in the recipe section about how to properly pluck and butcher a chicken before cooking.
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
30in Hydraulic Forks Skid Steer Attachment (A56857)
30in Hydraulic...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
