Old Barn used for equipment, You think this will work?
   / Old Barn used for equipment, You think this will work? #11
It's your barn you paid for it do what you want with it, I rather see a barn being used and maintain then abandon and on the verge of collapse...
Like some have said if its post and beam and you don't cut any beam it is ok to do so might need minor reinforcement and framing for a door frame and door support but that should be it.
If its bearing wall you will need beam and support for that beam ...
can't say by the picture provided.
   / Old Barn used for equipment, You think this will work? #12
Why don't you just build a shed instead of working over the old barn. It don't look like you're in Alaska, so a shed should be fine. Or, come off the sides of the barn with sheds.
   / Old Barn used for equipment, You think this will work? #13
It all depends on how it's framed. Considering it's age and how things where built back then, odds are very good that you can just cut out the siding and not have to do anything else.
Is it a Timber Frame Barn? or is it a Pole Barn with posts set in the ground? How did they lock the framing in place to deal with racking?
Post pictures of the interior framing and pictures of where you want to cut out the siding, to include how the roof it supported by that wall.
I disagree with everyone who says to leave it like it is because it's old and they like old barns. I feel strongly that it's more important to use a barn, and make it better to do what you need it to do.
   / Old Barn used for equipment, You think this will work? #14
Can you show the inside of the building? Maybe the wall where you want to cut an access too?
   / Old Barn used for equipment, You think this will work? #15
That's why I mentioned "save it".
The number of barns that I've seen "modified" (to put it kindly) by farmers who probably didn't know any better or simply didn't have a choice where primary posts or beams were removed....
I'm 100% with it's his barn, do what you like but I've just seen too many of them end up in a burn pile.
If running across an old classic wooden barn doesn't warm your heart and stir up fond memories, better get your heart checked. 👍
  • Good Post
Reactions: JJT
   / Old Barn used for equipment, You think this will work? #16
If you drop poles or posts in the ground (with concrete) for your door frame, there will be no load on the barn. If you attach the barn to the new door frames, you increase shear and load strength to the barn.
This example doesn’t even have top beam.
Removing the siding can reduce lot capacity of the roof as well as shear depending on framing method
in attached example there is no need for beam because there is nothing above door
   / Old Barn used for equipment, You think this will work? #17
Keep the barn exterior as is. Buy a cheap forklift to maneuver the implements into the stalls from the center aisle.
If the barn is old enough to be a real post and beam barn, there are no load bearing walls, the posts carry the load. I'm voting for saving the barn asis and building something new for the implements.
You are correct, it is post and beam.
   / Old Barn used for equipment, You think this will work? #19
The OP might want to top up the insurance on his equipment if it's important to him. The barn might last another 100 years but who knows.
I love those old barns, it's a shame to see them go down unexpectedly.
1454 (A57192)
1454 (A57192)
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2016 Ford Transit Connect Cargo Van (A56858)
2016 Ford Transit...
1983 KENWORTH W900 SLEEPER (A58018)
1983 KENWORTH W900...
Forklift Safety Basket (A56857)
Forklift Safety...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
