Old 35 clutch release fork parts help
   / Old 35 clutch release fork parts help #1
mwb
Platinum Member
Ottawa Ont Canada
3940HST Montana
I am fixing a late 50's 35 for a neighbour; he buggered up the clutch after splitting the tractor and it ate the release fingers, release bearing, bearing carrier and the release forks. I have sourced replacement parts except for the release fork (that attaches to the clutch pedal). The stamping number on the part is 181-459-M1 and matches the parts list I have for a 35 DeLuxe.
This part is not available anywhere I have looked; I have also searched for a generic "MF 35 release fork" and found a part number 886719M1 that is described as fitting many models... does anyone have advice for me? I can weld the old one to build it back up but would much rather fix it right.
   / Old 35 clutch release fork parts help #2
When I put in your part number without the dashes it pops up at Wengers....
Might be your best bet!
Thank you! (y)
UNUSED RAYTREE REDM32 HYD MULCHER (A60432)
UNUSED RAYTREE...
UNUSED FUTURE PG72-72" HYD PLATE GRABBER (A60432)
UNUSED FUTURE...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
UNUSED IRANCH 23" GRID SHAPED MINI EXCAVATOR BKT (A60432)
UNUSED IRANCH 23"...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
