Okay, what did I buy?
   / Okay, what did I buy? #1
daTeacha
Veteran Member
Funk, Ohio
Well, I went to an auction today. About 600 numbers were out, so it was pretty big. A Massey 231 with 45 hours on it went for $10500, which I thought was a pretty good price. A half ton Silverado in outstanding shape, 100k miles, 4x4, good cap, '93 model year went for 5700, again not bad.
I bought a 6' more or less wide 3 point disc that looks like it has mostly sat outside. I think I got it for a decent price at 135. There were 4 guys wanting it at the start, and the last bid prior to mine was 130.
It's pretty rusty on the surface, but the discs are all solid. They're 16" diameter, 5 per axle. It has mostly yellow paint left with a thin black pin stripe, but there are also parts that look to be faded JD green.
Does anyone know what brand it might be? Did John Deere ever make a small disc like it? All the adjustments are by bolt, no levers or anything like on the straight pull disc I had in Michigan. There are no weight boxes or anything. The thing weighs about 500 lb or so. It took 5 or 6 guys to lift it into the bed of my Dakota, where it just fit. I presume there are zerks on the thing somewhere but I haven't had a chance to do much other than lift it out of the truck and put it in the shop. The cutters all turn, and there is some grease showing on one set at the inboard end.
It doesn't appear that there is enough adjustment to the rear gangs to allow them to run very close to straight, which is how I plan to use it for slicing the ground open prior to overseeding the pasture. I figure I can adjust the top link so only the front blades make contact and gain the benefit of the weight of the rear set helping to cut into the ground.
   / Okay, what did I buy? #2
Pictures would be a great help, I bought one that matches your description with larger disc's and it red and it says King Kutter on it, I think? I havent paid much attention to it
   / Okay, what did I buy? #3
Deere has made a few versions of small lift-type disc's, but they're generally almost all green, and most are quite distinctive in their design. I once owned a Lienbach disc that somewhat matched your description.
For $135, it doesn't matter what brand you got. That's a good deal!
I checked prices at TSC prior to the auction. The new KingKutter ones are in the $500 to $600 range. I usually figure something essentially new at auction is worth 1/2 to 3/4 of the store price and something showing wear and/or neglect is half of that, so I was prepared to go to $175 on it.
Guns are another matter. While standing there holding an ad showing a Henry Golden boy .22 brand new for $350, I saw a slightly used one sell for $435. Go figure.
   / Okay, what did I buy? #5
In central PA, the auctions have seemed to take a turn for the worse. Some of the farm/tractor equipment I was looking to buy was getting bid up by people looking to scrap it. I stopped going to auctions for a little while, until the fall season is in, then people might not be inclined to buy something that they cant readily put to use.
I know what you mean about guns at auctions. I have always told my wife that if I die not to sell them to a dealer, get them sold at auction.
Preferably in an Amish community far from a bigger size dealer.
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A61306)
2015 Bobcat S650...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
