tweakimportz
- Joined
- May 25, 2011
- Messages
- 10
- Tractor
- mahindra 2615 ml 106
ok so i got the starter hooked up and it works fine.
now i started the tractor and it wouldn't turn off. im thinking ignition switch is shorted out, because i can turn it off and take the key completely out and it just stays running.
just seeing if there is a reoccurring problem like this.
also. when i hooked up the starter there was a solenoid on the other side of the engine i believe connected to the injectors that was getting extremely hott with the ignition turned on engine not running. just wondering if that is normal. glow plug or something idk i dont really work on tractors ill post some pics of the solenoid in question. later.
