OK to use 85W140 rather than 80W90 gear oil in a Super C parade tractor?
   / OK to use 85W140 rather than 80W90 gear oil in a Super C parade tractor? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I know 80W90 is spec gear oil for my 1947 Super C Farmall but that was then and this is now. The tractor only gets used in summer parades for maybe 100 miles a year in the heat of summer. I'd like to use 85-140 to slow down leaks but not sure if I should and if it's a good or bad idea. Do others use the thicker oil and does anyone have any experience or thoughts on this?
Thank you in advance.
   / OK to use 85W140 rather than 80W90 gear oil in a Super C parade tractor? #2
It should work OK as you won't be subjected to "Low" temps in the summer.
   / OK to use 85W140 rather than 80W90 gear oil in a Super C parade tractor? #3
Over 30 years ago I put new rear axels and seals in my 8N Ford along with 85-140 oil , it’s been working fine, about the only real difference I noticed is during cold winter weather it takes a while for the oil to warm up so the 3 point isn’t so slow.
   / OK to use 85W140 rather than 80W90 gear oil in a Super C parade tractor? #4
The cold points are almost identical on the two lubes, untill it gets worked and the oil temp starts to increase the viscosity will stay low
   / OK to use 85W140 rather than 80W90 gear oil in a Super C parade tractor? #5
I think that's a good idea, I do kind of the same thing on my bush hog gear boxes instead of using the recommended 80w90 weight oil I fill the gear box 1/2 full with grease. So far so good. (y)
   / OK to use 85W140 rather than 80W90 gear oil in a Super C parade tractor? #6
I have extreme faith in these old machines. I think you could pump the gearcases full of a good quality gun grease and they'd be fine. Especially considering your described usage. :cool:
Thanks for all the replies.
As for gear grease, a common remedy for for big farm tucks (F600 Ford, , etc) trucks was to fill he steering gear half with grease and half with gear oil. They worked fine and it leaked less or not all all.
48in Farm Jack (A55852)
48in Farm Jack...
2017 MOROOKA MST300VD CRAWLER DUMPER (A52707)
2017 MOROOKA...
Electric Mobility Scooter (A55853)
Electric Mobility...
Electric Mobility Scooter (A54815)
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
