OK to use 40-1 oil gas mix if out of 50-1 mix?
   / OK to use 40-1 oil gas mix if out of 50-1 mix? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have several saws with 50-1 and 40-1 oil/gas mix requirements, etc and ran out of my 50-1 fuel mix. Any issue with me running my 40-1 mix in the 50-1 saws? Doesn't seem to be any problem but I'm not up on these things. Is it OK?
   / OK to use 40-1 oil gas mix if out of 50-1 mix? #2
Not really other than if they idle for an extended period they may foul the plug. Mine rarely idle. Yours may however.
   / OK to use 40-1 oil gas mix if out of 50-1 mix? #3
Should not be a problem.
   / OK to use 40-1 oil gas mix if out of 50-1 mix? #4
Shouldn't be a big issue, but in reality running the 40:1 in the 50:1 items will cause them to run slightly lean, but will have more oil present for lube.
   / OK to use 40-1 oil gas mix if out of 50-1 mix? #5
Yep. It'll be a leaner air/fuel ratio. The carb meters premix. More oil means less fuel. But it's a small difference. Unless your carb is tuned extra crispy lean it'll be fine.
   / OK to use 40-1 oil gas mix if out of 50-1 mix? #6
No problem. I never ever worried about having different "recommended" mixes for each engine.
Now that I have no small engines by order of the doctor (have an ICD in my chest), I'm a much happier camper. Plus, my wife has taken over the chain saw work with battery powered chain saws. She can start them.
Ralph
   / OK to use 40-1 oil gas mix if out of 50-1 mix? #7
Ralph
My wife can start my 075 Stihl no problem.....:laughing:
   / OK to use 40-1 oil gas mix if out of 50-1 mix? #8
I tune all ope to 40:1. Just tune to your mix. All my stuff is ran 40:1. I wont do the epa 50:1 myself.
I have only had 1or2 saws come back in 15-18 years. When owner ran 50:1 wouldnt idle right after I had tuned for 40:1. So I then just tuned to his 50:1 for him.
Booster Cables (A55852)
Booster Cables...
378467 (A51572)
378467 (A51572)
2025 Swict 78in Bucket Skid Steer Attachment (A55851)
2025 Swict 78in...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
Tiger Mower Flail Arms (A55851)
Tiger Mower Flail...
2018 Kubota U17 (A53317)
2018 Kubota U17...
