Ok so I replaced the gas line and fuel bowl and then
   / Ok so I replaced the gas line and fuel bowl and then #1
rjhans53
Mulberry, FL
Iseki 1910 Ford 8n B
The starter goes out. So I take it apart, knock all the rust out and bingo, it works, well for about 2 days. So I order and replace the starter, and she fires up like a dream. I fiddle with the linkage and the carb and low idle is about 450 and high (throttle all the way on to the where it stops, I do still have a quarter of the plate left) is around 2150, the book says 2200 I figure 2150 is ok. At the 450 it's a rough idle but it holds, driving the thing around there seams to be a slight miss even at all out, I'm thinking I probably need to replace the plugs as I've been messing with this thing forever and maybe have them fouled??
   / Ok so I replaced the gas line and fuel bowl and then #2
Maybee fouled? Probably took longer to type than pull and clean and regap. :)
Let us know what you find, may give you some clues as to flutter.
1999 Honda VT1100C Motorcycle (A51694)
1999 Honda VT1100C...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
1998 WABA Van Trailer (A53117)
1998 WABA Van...
UNUSED 5 Gallon Buckets (A53117)
UNUSED 5 Gallon...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
