Ok so I replaced the gas line and fuel bowl and then
   / Ok so I replaced the gas line and fuel bowl and then #1
rjhans53
Mulberry, FL
Iseki 1910 Ford 8n B
The starter goes out. So I take it apart, knock all the rust out and bingo, it works, well for about 2 days. So I order and replace the starter, and she fires up like a dream. I fiddle with the linkage and the carb and low idle is about 450 and high (throttle all the way on to the where it stops, I do still have a quarter of the plate left) is around 2150, the book says 2200 I figure 2150 is ok. At the 450 it's a rough idle but it holds, driving the thing around there seams to be a slight miss even at all out, I'm thinking I probably need to replace the plugs as I've been messing with this thing forever and maybe have them fouled??
   / Ok so I replaced the gas line and fuel bowl and then #2
Maybee fouled? Probably took longer to type than pull and clean and regap. :)
Let us know what you find, may give you some clues as to flutter.
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
