Ok so I replaced the gas line and fuel bowl and then
   / Ok so I replaced the gas line and fuel bowl and then #1
rjhans53
Bronze Member
Mulberry, FL
Iseki 1910 Ford 8n B
The starter goes out. So I take it apart, knock all the rust out and bingo, it works, well for about 2 days. So I order and replace the starter, and she fires up like a dream. I fiddle with the linkage and the carb and low idle is about 450 and high (throttle all the way on to the where it stops, I do still have a quarter of the plate left) is around 2150, the book says 2200 I figure 2150 is ok. At the 450 it's a rough idle but it holds, driving the thing around there seams to be a slight miss even at all out, I'm thinking I probably need to replace the plugs as I've been messing with this thing forever and maybe have them fouled??
   / Ok so I replaced the gas line and fuel bowl and then #2
Maybee fouled? Probably took longer to type than pull and clean and regap. :)
Let us know what you find, may give you some clues as to flutter.
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
