Ok, got my First Problem (455)
/ Ok, got my First Problem (455) #1
gager2002
Was running as test out. After about 3 minutes, it started to smell as if burning (rubbing) metal. Then started to smoke around the starter area. I killed it as soon as I saw the smoke. Checked the oil before running an it was ok level. There is evidence of the started being convinced to turn over, (witness marks on the outside). Now it ast as if the starter has gone out. Which is fine! I noticed threre are several yellow 'oil' caps in various locations. I am not sure which one is what or the drains and filters that correspond to each other. As I pulled it back to the garage (that wasn't fun) the rear axle was making a click-clicking sound. Any ideas??? Thanks guys. Any help would be appreciated.
/ Ok, got my First Problem (455) #2
How did you pull it back to the garage?
Did the manual tell you how to dis-engage the hydro tranny to pull it?
Opps. What Manuel? After about 10 steps uf pulling I stopped and put a floor jack under the rearend. On another note, I know my start is bad. Price thr silly thing at $330. Is this what I have to look forward too. $$pricey parts??
/ Ok, got my First Problem (455) #4
JD parts are pricey. That's a yanmar starter with a yanmar part # (I believe). If not, see below. Contact your local yanmar dealer for a cheaper sub.
You don't have to buy the entire starter... pieces and parts are available.
Here are the equalivent starter part #'s
Nippondenso 028000-7640
Nippondenso 5702800-764
Nippondenso 9712809-074
John Deere AM100809
John Deere CH12084
Lucas S9976
Yanmar 119385-77010
Yanmar 124520-77010
PFI S-ND17099
Looking at the aft end of the tractor: on the right hand side, just outside the frame rail. There's a 1/4" dia. rod that comes back and hooks to nothing. The rod needs to be down for normal use, up for towing/pushing.
/ Ok, got my First Problem (455) #5
And NEVER park without setting the parking brake because it eventually WILL roll freely once the system bleeds down. I had a friend use and park mine once...
/ Ok, got my First Problem (455) #6
Look around for an automotive electrical repair shop. You can probably get it rebuilt a lot cheaper than buying a replacement and it'll be good as new.
It will save you a lot of aggravation and maybe damage to the tractor if you bite the bullet and get a manual. I'm as cheap as the next guy but you can fool around and cost yourself some money...
My wife used to be in the business and we have two 455's. One is all wheel steer with 54" deck and the other has the 60" deck. I'm pretty familiar with both, but still refer to the manuals for both the decks and the tractors. I just can't remember EVERYTHING.
Someone tell me the best place or link to buy or order a manuel.
/ Ok, got my First Problem (455) #8
JD Manuals
Note that there are two options for the 455 garden tractor, depending on your serial number.
/ Ok, got my First Problem (455) #9
You are a better man than I am if you pulled that 455 ten steps without dis-engaging the hyd transmission. /forums/images/graemlins/grin.gif
There is a lever (handle) on the right side under the seat between the frame and the right rear wheel that lifts up. That opens the hyd. line that allows the 455 to roll much more freely. Hopefully you will find a manual, and get a good fix on the starter. Remember, the value of your machine doesn't come from having cheap parts. /forums/images/graemlins/wink.gif
I know, but I don't want to invest alot at first if there are some deeper root prpblems and could cost a lot $$. I found a place that will rebuild my current started for $30 plus parts. While that is in the works - I bought all the filters. Now, for the manuels - I will go buy the big dealership and see if I can buy them there instead of ordering. I need to find out the procedures ion changing the fluids and how much fluid to put it. One person told me to change the oil about 3 times in a row with running the tractor about 1-3 hours in between. Any ideas on that? It has been a while since anything has been changed.
/ Ok, got my First Problem (455) #11
Sounds good on the starter repair.
As far as oil, I'd take a good look at the oil you drain, and if it appears to flow from the engine drain okay, and is not sludge, I would proceed with a change of filter and oil, then do it again in 50 hours.
If it comes out as sludge, I would put new oil in but not change the filter. Then run a few hours and change the oil and the filter after that. I would expect that the filter would be plugged if there is sludge, and until some of the sludge gets flushed out the crankcase, that a new filter would not be beneficial. Do what feels good to you.
/ Ok, got my First Problem (455) #12
I seem to recall the service & parts manuals cost me $160.
Fluid qtys per manual are:
Engine oil 3 qts with filter
Hydro 7 qts with filter
Cooling system 3 qts
Fuel capacity 6.5 gal
What about the guys selling the CD on ebay. There are lots of them. Are they worth looking into. They title it 'Factory Service Manual'. Is this one of the things I am looking for?
/ Ok, got my First Problem (455) #14
I have been talking about him getting the Operator's Manual. The one that comes with the tractor when purchased.
From the questions asked, this man needs to learn the basics (oil filters, buttons, hydraulics, switches, deck adjustment, tire pressure, specifications, service schedule, etc) for the tractor, and what is what and where. /forums/images/graemlins/wink.gif
Suspect it is about $15, but I don't know.
159115 (A60430)
159115 (A60430)
John Deere 7200 6R Planter (A66285)
John Deere 7200 6R...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
