oil
mulitweed
john deere
I usually buy Mobil delvac when its on sale , I try and use the same oil dos that make sense?
Yes, if it meets specs. for your equipment and you change it along with a properly specc'd filter @ recommended intervals.
Delvac is a quality oil and I use it also. I always use OEM oil filters and I usually stick with the same oil. Annual engine oil and engine oil filter changes every Fall.
No problems so far but I avoid off-brand filters and engine oil. I may be cheap but not to the point where I may endanger an expensive piece of equipment.
/ oil
I usually run napa filters
Hydraulic rail grinder (A61307)
Hydraulic rail...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2017 Mack Semi (A64047)
2017 Mack Semi...
2022 EZ-GO ELITE...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
