oil weight??
   / oil weight?? #1
seabee1966
prince frederick,maryland
international 234
I just bought an older international 234 with a mitsubishi k3b engine,what weight oil do i put in it,as i want to change the oil and filter.
   / oil weight?? #2
:welcome: to TBN!
I'm going to let someone closer to you answer that question.
Down here, I run 15w-40 in all my diesels. Big truck, pickups, tractors. But, it doesn't get as cold here.
   / oil weight?? #3
I was going to say I run Shell T6 5w40 synthetic in my tractor and my Dodge Cummins. I run Mobil1 Truck and SUV diesel in my diesel car. The T6 oil is about $19-22 a gallon. Mobil is more expensive. The synthetics flow better when cold which makes cold starts a bit easier and possibly less wear.
   / oil weight?? #4
Plenty of 5w30 semi and full synthetic oils out there to choose from, even a Castrol one from VW dealers for TDI engines that they (at least our local dealer) don't over charge for. A 5w30 is what I'd use.
Ralph
   / oil weight?? #5
I'm in Maryland near the PA line and my tractor dealer, Walter G. Coale's in Churchville, MD says 15-40 year round. I use Shell Rotella.
   / oil weight?? #6
A 10w30 like shell rotella t5 syn blend would be good. It is on sale for $14 and change at wal mart per gallon.
   / oil weight?? #7
I've used Shell Rotella 15w-40 and when it's cold, my MX5100 makes a loud buzzing sound for a bit at the first startup when colder than 40 deg F. I believe it's probably the oil pump, but don't know for sure. I'll be switching to T-6 5w-40 at the next oil change.
HP
   / oil weight?? #8
I use Chevron DELO 400 LE in everything. Have for 50 years. I get it at NAPA on their fleet discount which they give for a Military Discount. 40% less than Costco.
Side issue; what is your Seabee background? I retired after 33 years as a W4, CEC and a former UTC. As a warrant I had a couple CESE management assignments. Welcome aboard to the best forum on the Net.
Ron
Ron
   / oil weight?? #9
i would use a 15w-40 in summer and if u like a syn oil or something more like 5w-40 or 10w-40 deisel rated for winter flow.
   / oil weight?? #10
As always, I recommend going to the manufactures site and use what they recommend. There is no one here who knows better than the manufacturer what is best for their engine.
Walt Conner
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
Generac S/A Towable Light Tower. (A52377)
Generac S/A...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
