oil weight change
   / oil weight change #1
deereman64
I have been running 5w 30 Rotella synthetic for the last 90 hours which has been the basically last winter and spring. I changed last night to Mobil1 synthetic 15w 50 as I worried that the summer heat was going to over tax a lighter oil. I have a jd 2210 and they recommend a 15w 40 ,but I could nt find any.
Am I being over indulgent?
   / oil weight change #2
That is getting a little thick, where are you located and what are your max outdoor temps like? Oil that is to thick can hold air bubbles (foam) easier than a thinner viscosity. The air is not released as quickly as it would be in a lighter weight oil. It will also increase the fuel consumption a little. The thicker the oil the more drag it induces which takes away a little HP.
   / oil weight change
Im in southern new york. Its been warm so far this year and Im thinking that its going to get quite hot 90 to over 100 during july
   / oil weight change #4
Why couldn't you find 15w-40? It's the most common weight of diesel oil. I have to look hard to avoid it.
   / oil weight change #5
That's actually not that hot. I would stick with a 15W/40 viscosity oil in that temperature range. The only time I "might" go with something thicker would be extended operating times in a desert climate with constant temps in the 120+ deg range. As long as your cooling system is functioning as designed the engine should not be running any hotter than normal.
   / oil weight change
I went to Tractor supply and Walmart and they were cleaned out. Have to be honest though, the wife was out and I wanted to do it quickly that evening. I do plan to switch back to 5w30 in December.
   / oil weight change #7
Cleared out of 15W/40. :eek: Wow, that's rare since it is the most popular weight diesel engine oil there is.
   / oil weight change #8
?? Thats strange?? The Rotella SYN that I have here if 5W-40...not 5W-30??
If you have done oil and filter changes on the proper sched..you dont need a 50 weight oil at all.
   / oil weight change #9
Its 92 here where I am RIGHT NOW!!!!
   / oil weight change
You're right it was 5w40 sorry.
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55218)
Kubota BX2680...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
