Oil Sprayer for UTV for dust control?
/ Oil Sprayer for UTV for dust control? #81
found here. Carcinogenic potential of gasoline and diesel engine oils. - PubMed - NCBI
McKee RH1, Plutnick RT.
Author information
Abstract
Used gasoline engine oils are carcinogenic in mouse skin and mutagenic in Salmonella. The toxicity of fresh gasoline engine oils and that of fresh and used diesel engine oils are less well defined. The present studies examined the dermal carcinogenic potential of a series of fresh and used oils from both gasoline and diesel engines. The used oils represented a variety of operating conditions. The objective of the study was to assess the potential carcinogenic hazards associated with exposure to these materials. The majority of the used gasoline engine oils tested were carcinogenic although one oil, collected after a relatively short drainage interval, was inactive in the dermal carcinogenesis bioassay. Additionally, polycyclic aromatic hydrocarbon (PAH) concentrations were elevated in the used oils in comparison to the fresh oils. The fresh gasoline engine oils and both the fresh and used diesel engine oil samples were noncarcinogenic, and there was little evidence of elevated PAH levels in the used diesel engine oils. The carcinogenic potency of used oils from gasoline engines was related to drainage interval, but other factors such as contribution of the fuel due to blowby and driving cycle may also have been important. The used diesel engine oils were not carcinogenic even after extended use.
/ Oil Sprayer for UTV for dust control? #82
Silly....the lab analysis tests for wear metals commonly found in internal combustion engines and says nothing about toxicity. Like giving someone a math test to see how well they spell. Even more misleading is your lab results only represent wear metals in your engine for a defined period of time. Only a complete idiot would give any credence to your so called 菟roof that used motor oil is not hazardous.:laughing::laughing:
Are you saying there are super secret compounds not found on the "elements" section of an analysis? It's always the "other" thing that can't be defined that is going to prove your point, right? When you find that other thing hiding in plain sight, let me know.
Until then I will continue to enjoy be oil laden driveway.
/ Oil Sprayer for UTV for dust control? #83
Author information
Abstract
Don't drink used motor oil or bath in it.
It's not rocket science.
/ Oil Sprayer for UTV for dust control? #84
I put him on ignore long ago. No point in trying to reason with a fool.
But you still knew who he was banging his head against, that's not how the ignore function works. If it wasn't obvious.
/ Oil Sprayer for UTV for dust control? #85
If those so worried about oil on roadways...you should lead by example and not drive on any asphalt based road. After all, emulsified oil keeps the aggregate together.
So us how your concerns translate into action.
/ Oil Sprayer for UTV for dust control? #87
If the OP wanted to stir up disagreement in the group, he's succeeded.
/ Oil Sprayer for UTV for dust control? #88
If I'm reading the information about the OP correctly, he joined nearly ten years before posting his first and only message. Things must have gone smoothly until last month.
Join Date03-15-2010
Last Activity02-08-2020 10:55 AM
/ Oil Sprayer for UTV for dust control? #89
Join Date03-15-2010
That is funny right there.....:cool2:
/ Oil Sprayer for UTV for dust control? #90
I see snoober is running in overdrive...lol I cannot read his comments (unless I choose to) and I don't choose to.
/ Oil Sprayer for UTV for dust control? #91
I see alot of potential Darwin award recipients here-unfortunately the crap they are pulling will affect generations to come. Maybe these recipients will only affect their own kind as they inherit the property after them? Not some poor family that unknowingly knows what is done to the property before.
I hate people sometimes.....
/ Oil Sprayer for UTV for dust control? #92
Would the solution be to tear up my asphalt driveway?
/ Oil Sprayer for UTV for dust control? #93
There seems to be a logical disconnect where people are ok with asphalt roads but can stand oil on a roadway.
Can someone explain to me the difference, please.
/ Oil Sprayer for UTV for dust control? #94
How much petroleum washes out of asphalt and into the water supply?
/ Oil Sprayer for UTV for dust control? #95
Ever see a wet new road surface compared to a old wet road surface? The oil sheen is present in one and not other. What happens to it?
/ Oil Sprayer for UTV for dust control? #96
Now what are you doing asking a question like that,
you know they can't answer it.
It's about like looking in the water puddles on or down from a shale ledge, that blue oil sheen.
/ Oil Sprayer for UTV for dust control? #97
I built a sprayer that goes in the back of my Kubota RTV. Have a friend that gives me all of his used vegetable oil from his 6 restaurants .....I strain it and lay it down on the road.....works great.
/ Oil Sprayer for UTV for dust control? #98
I've touched many a wet road surface and it didn't feel oily. Unless the oil came from leaky autos. Very few people want to live in a toxic environment. Staying off the roads is not an option. Not spraying motor oil on them is.
Now go ahead and get the last word in.
2019 Yongfu Scooter (A59231)
2019 Yongfu...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Freightliner Fuel Truck (A61306)
Freightliner Fuel...
2022 CATERPILLAR PM622 COLD PLANER (A60429)
2022 CATERPILLAR...
UNUSED ZJG ZJ-13 EXCAVATOR (A60430)
UNUSED ZJG ZJ-13...
