Oil Sprayer for UTV for dust control?
/ Oil Sprayer for UTV for dust control? #1
Ampped
Lincoln, CA
Kubota L2800
I'm looking to build a sprayer that would sit in the back of my UTV that would allow me to spray used oil on my roads to help with dust control. I have a 16 gallon spot sprayer with custom boom for weed control but at 2.2 gpm and 70 psi it doesn't seem to have enough power to distribute oil. Thinking maybe something with a larger 12 volt pump or maybe small gas motor. What kind of pressure and nozzles would be reguired? Anyone out there fabricated anything like this? Thanks in advance for any help!
/ Oil Sprayer for UTV for dust control? #4
Haven't seen that done in forty years.May be a fine involved.
/ Oil Sprayer for UTV for dust control? #5
Oil for dust control? California? This is a joke, right?
/ Oil Sprayer for UTV for dust control? #6
Hemp oil in a pressure washer. Add some THC for California use. LSD for Bay Area roads.
/ Oil Sprayer for UTV for dust control? #8
Used vegetable oil would be allot better then used crankcase oil.
/ Oil Sprayer for UTV for dust control? #9
I think Hillstreet said it all...........
/ Oil Sprayer for UTV for dust control? #10
What ever product that you use for dust control from the different polymers to calciums,
I wouldn't bother with a sprayer and nozzles that will plug and act up.
A 6 to 8 ft pipe with numerous holes and a good sized full flow ball valve a simple gravity flow system.
/ Oil Sprayer for UTV for dust control? #11
Just be careful of getting oil of getting oil into the groundwater and causing damage.
/ Oil Sprayer for UTV for dust control? #12
Must be a troll. No one in their right mind would put used motor oil on the road, especially in Kalifornia.
/ Oil Sprayer for UTV for dust control? #13
When I was a kid my dad did it.....it sure isn't something I'm proud of. When we finally succeed in screwing up this planet, where do we go?
/ Oil Sprayer for UTV for dust control? #14
I'm looking to build a sprayer that would sit in the back of my UTV that would allow me to spray used oil on my roads to help with dust control. What kind of pressure and nozzles would be reguired?
Al Gore bored and playing around on the interweb he invented or what?? Regardless, you're going to need something along the lines of an Ingersoll Rand 185CFM compressor to push that thick of viscosity. As for nozzles.........bigguns. Good luck and be sure to post some build pictures. We like pictures.
/ Oil Sprayer for UTV for dust control? #15
guys...oil comes from the ground and is broken down by normal enzymes found in nature.
The spot on the ranch where old oil was dumped many years ago is now one of the greenest parts of the place.
relax...
/ Oil Sprayer for UTV for dust control? #16
My JD tractor has a tiny bottle under the SCVs to catch the four drops of oil that might otherwise pollute the earth when you disconnect. Give your head a shake.
I even thought about moving my fuel tanks from time to time to lessen contamination in one spot. If the place was ever up for sale, they could do a soil test at the fuel tanks and decide that a two million dollar soil reclaimation is in order.
/ Oil Sprayer for UTV for dust control? #17
Only in Canada....eh?
/ Oil Sprayer for UTV for dust control? #18
Around here they use wood resins that they somehow boil out when processing timber.
Works OK but gets washed out after some weeks.
Sure is gooey stuff when put down.
/ Oil Sprayer for UTV for dust control? #19
Use that here too. Gets on your shoe bottoms and tracks everywhere...
/ Oil Sprayer for UTV for dust control? #20
relax...
Yep, I had an environmental disaster of a Toyota powered log splitter that sat in the same spot in my yard for 20 years. Ground is saturated with motor and hydraulic oil and coolant that leaked from that thing those 20 years. I finally quit using it and moved it. And just as Snobdds said....that spot is the longest, greenest grass in my yard?? LOL
Even my city used to use oil on the roads back in the day. They still do in the steel mill on their roads. And we are still all alive after all these years.
2022 New Holland C327 Compact Track Loader (A61306)
2022 New Holland...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
2006 Lufkin 45ft. 40 Ton T/A Flatbed Trailer (A59230)
2006 Lufkin 45ft...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2015 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2015 FREIGHTLINER...
2017 HAMM H5i P PADFOOT ROLLER (A60429)
2017 HAMM H5i P...
