oil sender adapter
/ oil sender adapter #1
tmar04
YM 276
Hello to all, I have a YM2500 and am trying to install a manual oil pressure gauge, instead of the light. I did this once before on a Yanmar, and can't remember what kind of adapter/fitting I have to have to screw into the block to mate up with the manual fittings. Seems like it was British pipe thread or something like that. any help would be appreciated.
/ oil sender adapter #2
My Kubota uses a 1/8" British Pipe Thread. McMaster Carr has brass adapters that work well. The 1/8" British and 1/8" US pipe threads are so close that you can often screw them together for a few turns, but they invariably leak. If you use a TEE and a couple of adapters, and If you have enough room, you may be able to keep the ldiot light sending unit and all the guage sender as well.
/ oil sender adapter #3
Thats a good idea about keeping the idiot light too,along with the mechanical gauge.The gauges are great,but after awhile you get tired of looking at them and a red light is more noticeable,especially at night even if you do have the gauge lit up.
If you are going thru the trouble,i'd keep them both......digger2
/ oil sender adapter #4
I also second the sugestion on 'T' ing the line and keeping the idiot lamp and the manual gauge. best of both worlds.
soundguy
/ oil sender adapter #5
Another vote for "teeing," if for no other reason than the oil line between the fitting and gauge on mechanical gauges can break (vibration, work hardening, abrasion, ...) causing an oil leak. The light may help avoid damage...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
1997 LEDWELL 48FT DOVETAIL TRAILER (A63569)
1997 LEDWELL 48FT...
2014 VOLVO VNL (A63569)
2014 VOLVO VNL...
2016 Ford F-250 4x4 Pickup Truck (A61573)
2016 Ford F-250...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
