Oil & Fuel oil pump problem
/ oil pump problem #1
fred jr
1972 kubota l-175
l-175 kubota will the oil pump stop pumping after it runs for 1 hr and the motor starts knocking, or is the oil breaking down?
/ oil pump problem #2
I have never seen an oil pump stop working then start working again. Most of these oil pumps are gear driven off the front geartrain and are very reliable. Possible causes: low oil level, incorrect grade of oil, debris covering and uncovering pick-up screen, pick-up tube loose, sucking air on supply side of pump, worn out pump, worn out bearings, sticking oil pressure regulator, etc. Put a mechanical gauge in an oil galley and watch pressure hot and cold at various rpm's. Before this question was even asked, I would have changed oil and filter to evaluate. How many hours on this engine? How many hours since last oil change? Philip.
/ oil pump problem
Thanks a lot Philip, just know getting into the problem. Changing oil and filter is the first thing I will do.... Fred Jr.
/ oil pump problem
Thanks a lot Phillip, just now getting into the problem. First thing I will do is to change the oil and filter. fredjr..
2022 BOBCAT T66 R-SERIES SKID STEER (A65053)
2022 BOBCAT T66...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
2018 F-150 4WD (A63689)
2018 F-150 4WD...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
