oil pressure port
/ oil pressure port #1
Tachdriver
Kubota bx25
Where is a good place on the BX25 engine to tap into for engine oil pressure ?
Later
/ oil pressure port #2
Your engine should have a sending unit
for oil pressure and the dash should have
an oil pressure guage of some type.
Do you have a guage that is not working?,
and or do you wish to change it to a
pressure type guage?
/ oil pressure port
I am installing a gauge
later
/ oil pressure port #4
I have the light to warn of low oil pressure and I just removed the sender and installed a T, reinstalled the sender and attached a line to my new gauge. That way the light still works.
/ oil pressure port #5
leonz, the BX only has a low oil pressure light. maybe he is asking if he can "T" in or use the same port for a pressure gauge instead ? any thoughts guys ?
/ oil pressure port #6
Yes that would work for sure.
/ oil pressure port #7
This is the proper way to do it...unless eliminating idiot light...then just exchange senders, with adapter(s) if necessary.
Not a fan of mechanical gauges...too great a chance for leaks.
/ oil pressure port
Ok I found it - the sender is right next to the oil filter, I'll tee in
thanks
later
2011 Ford E-350 Passenger Van (A64556)
2011 Ford E-350...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
Skid steer Backing Plate (A62679)
Skid steer Backing...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
Stout Buckets XHD 84 Grapple Skid Steer Bucket (A65640)
Stout Buckets XHD...
