oil pressure port
/ oil pressure port #1
Tachdriver
Kubota bx25
Where is a good place on the BX25 engine to tap into for engine oil pressure ?
Later
/ oil pressure port #2
Your engine should have a sending unit
for oil pressure and the dash should have
an oil pressure guage of some type.
Do you have a guage that is not working?,
and or do you wish to change it to a
pressure type guage?
/ oil pressure port
I am installing a gauge
later
/ oil pressure port #4
I have the light to warn of low oil pressure and I just removed the sender and installed a T, reinstalled the sender and attached a line to my new gauge. That way the light still works.
/ oil pressure port #5
leonz, the BX only has a low oil pressure light. maybe he is asking if he can "T" in or use the same port for a pressure gauge instead ? any thoughts guys ?
/ oil pressure port #6
Yes that would work for sure.
/ oil pressure port #7
This is the proper way to do it...unless eliminating idiot light...then just exchange senders, with adapter(s) if necessary.
Not a fan of mechanical gauges...too great a chance for leaks.
/ oil pressure port
Ok I found it - the sender is right next to the oil filter, I'll tee in
thanks
later
2007 International 9400i T/A Sleeper Cab Truck Tractor (A64194)
2007 International...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
Bandit Stump Grinder Model 3500 T (A62679)
Bandit Stump...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
2019 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2019 ROCK SOLID...
