oil pressure port
/ oil pressure port #1
Tachdriver
Kubota bx25
Where is a good place on the BX25 engine to tap into for engine oil pressure ?
Later
/ oil pressure port #2
Your engine should have a sending unit
for oil pressure and the dash should have
an oil pressure guage of some type.
Do you have a guage that is not working?,
and or do you wish to change it to a
pressure type guage?
/ oil pressure port
I am installing a gauge
later
/ oil pressure port #4
I have the light to warn of low oil pressure and I just removed the sender and installed a T, reinstalled the sender and attached a line to my new gauge. That way the light still works.
/ oil pressure port #5
leonz, the BX only has a low oil pressure light. maybe he is asking if he can "T" in or use the same port for a pressure gauge instead ? any thoughts guys ?
/ oil pressure port #6
Yes that would work for sure.
/ oil pressure port #7
This is the proper way to do it...unless eliminating idiot light...then just exchange senders, with adapter(s) if necessary.
Not a fan of mechanical gauges...too great a chance for leaks.
/ oil pressure port
Ok I found it - the sender is right next to the oil filter, I'll tee in
thanks
later
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2001 Ford F-550 (A66408)
2001 Ford F-550...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
Copper Rooster Weathervane (A65583)
Copper Rooster...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
