oil pressure low
   / oil pressure low #1
bmartin
Bronze Member
nc
Farm Pro 2425
I just changed oil for the first time in my Farm Pro 2425 and the pressure seems a little low after warming up. How do I go about increasing the pressure?
Billy
   / oil pressure low #2
What oil did you use? how low is low? specs call for minimum .05 kpa at idle, .2-.4 at operating speed. If you used sigle weight oil, like straight 30w. it will thin as it warms and the pressure will drop.
There is a regulator on the filter housing but it will not increase the pressure above what the pump puts out.
Use a good 15w40 oil will reduce the effect of temperature on the oil pressure.
   / oil pressure low #3
Mine did the same thing when I changed the oil and filter. I put high quality Shell 15w40 and my oil pressure noticably decreased. At first I thought I did not add enough oil but after checking it several times found it fine. There was a posting a while back about someone having to adjust their oil pressure. I am not sure what the outcome was though. You might do a search for it here on TBN
   / oil pressure low
Yeah, I changed to 15W40 and thats when it dropped, and like you I thought I remembered somebody else with the same problem and a solution. All I know is the stuff I drained out looked pretty dirty but held the pressure up. Now with a oil change and new filter I get the pressure drop.
I don't understand all I know about this!
Billy
   / oil pressure low #5
Billy, just my 2 cents but if it aint broke don't fix. I have run mine with new oil for 8 hours and it has not improved in pressure, I was thinking a, the sending unit is broken or not operating correctly or b, the oil pressure is truely low. Like you the stuff that came out of it was black gunk and it only had 8 hours of use. The new oil is still clean, and it has 8 hours. It is very hard to see on the dipstick. Go figure???
   / oil pressure low #6
An oil change will usually lower the oil pressure because the new oil that you put in is thinner than the oil you drained out. All oil thickens while it runs around in your engine. Synthetic oil does not thicken hardly at all however.
Anyhoo, if your oil pressure is too low (whether or not as a result of an oil change) you could be doing expensive damage to your engine so you need to be sure that you have the rated oil pressure at the rated speed (you typically have lower oil pressure at lower speeds so there will be a pressure listed for a certain speed).
   / oil pressure low #7
</font><font color="blue" class="small">( the stuff that came out of it was black gunk and it only had 8 hours of use. -SevenCorners )</font>
8 hours shouldn't make gunk. I wonder if they keep costs down by using reclaimed oil for that initial fill.
Worse yet, it just ocurred to me: I wonder if this is the Jinma factory's hazardous waste disposal plan!
   / oil pressure low #8
Hard tellin' what kinda crap was in the crankcase originally, and I've been wholly under-impressed with Chinese filters. Your initial pressure could have been as a result of sludge and/or a blocked bypass valve.
Everybody has their personal preference in oil and filters. The main thing is to use a filter that is specified for use on diesel engines. I wouldn't use one that has all gasoline engine applications. And make sure the Service Rating on the oil starts with C.
Then adjust the oil pressure sending unit. It's a pressure rheostat (a round silver thing) sticking out of the engine block, lower left side. One wire comes off it, heading up towards the dash. Rotating it left will lower the indicated oil pressure, right will indicate higher. With the (cold) engine OFF and the ignition switch to RUN, rotate the OPSU so the needle is dead center on the zero pressure mark. That should calibrate it for future reference.
Just so there's no confusion though, this has NO affect on the actual oil pressure itself. The procedure is simply to adjust the OPSU for the most accurate indication on the gauge.
//greg//
   / oil pressure low #9
mine never worked correctly (oil gauge) so I replaced it with a elcheapo 9 buck dirrect PSI reading gauge, this way I KNOW what the pressure is and how it is working all the time... COLD above 60 degrees ambiant starting pressure at idle is ~75 PSI, warm idle it is ~60 PSI, below freezing high idel it runs ~90 PSI and warm back to the ~60 PSI
PTO speed the pressure warm is ~65PSI
hope that helps...
Markm /forums/images/graemlins/cool.gif
OH forgot to say mine has the independant gauges and I'm GLAD it does!
   / oil pressure low #10
Mark
FWIW, Jinma specs indicate your Y385 is engineered to develop 58 psi of oil pressure at 1300 rpm (warm).
Sounds like 9 bucks well spent.
That below zero PSI is a very good example of why the right oil filter is so important. I prefer not to think of the wrong bypass valve recycling unfiltered oil in the direction of the cold upper cylinders.
//greg//
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2015 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2015 FREIGHTLINER...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
