oil pressure low
/ oil pressure low
Thanks Spiker, I'll keep your solution in mind. You know, I think these tractors all have a problem with the fluids. My hydraulic system was full of something that foamed like hell. Finally blew so much out I had to replace it and cleaned the filter which was full of trash, and after that the system works fine. Now I am wondering whats in the transmision. Molasas probably!
Billy
/ oil pressure low
Spiker, where did you hook up the pressure line and did the guage fit the old hole?
Billy
/ oil pressure low #13
I second it, Spiker what is the make/model of the oil presure gauge you have and where did you buy it? This post has me concerned I need to ensure my correct oil pressure. Heck I am even seriously thinking about changing all fluids based upon this thread.
/ oil pressure low #14
Hey guys:
I bought mine (actually bought a 3 gauge kit for 9.99 at ODD LOTS / BIG LOTS for an old tempo. Never installed it but all the gauges are sepperat and have a mounting plate to combine the 3 into one. anyhow the gauge kit came with all the needed adaptors as the outlet @ the oil pressure sending unit on the left side of the block above the tach sender is a 1/4" or 1/8" NPT tap. (forget which) you can buy a 1/4" T and install the gauge right off the "T" fitting if you wanted. I used the supplied HOSE and Fitting for the dash install. My 284 has individual gauge cluster and the replacement bolted right up. the chrome ring has rusted a bit from leaving it outside a lot but hey it was 9.99 for all 3 gauges so not out muchfor a replacement.!!! (also still have the Water Temp and the 60 AMP alt gauge, which I haven't installed yet... the factory ampmeter works well and hasn't broken...
/forums/images/graemlins/smile.gif
Mark M
/ oil pressure low
Thanks Spiker, I'll check out Big Lots tomorrow. Your mod looks good to me.
Billy
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
(INOP) GRAVELY ZERO TURN LAWNMOWER (A59823)
(INOP) GRAVELY...
Giyi Gy-BS72B QA BoxBroom Sweeper (A60463)
Giyi Gy-BS72B QA...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
