oil prerssure guage
/ oil prerssure guage #1
karter3947
I have a Homier farm pro 2425 4wd, diesel tractor, with only 54 hours on it. My oil pressure guage has always been a little off, but stayed low end of blue. (OK) I was idleing, and it dropped off to low end,(red) with no other change in engine sound. I shut it off. Is there a way to check if it is` the guage, the sending unit, or a oil pump??? I have had trouble with the fuel guage too. Walt
/ oil prerssure guage #2
There are probably ways to test the gage and sending unit, but the easiest way is to check or replace it with a mechanical gage. They're not very expensive.
/ oil prerssure guage #3
I would check the pressure with a mechanical guage set first. If the oil pressure is good, then check voltage to sender. More than likely you have a bad sender, as guages don't go bad too often. You could skip the pressure check and go right to the sender if you don't have a guage set, but I like to check pressure first.
2004 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2004 V.E...
3ft. 5-Point Metal Star (A61569)
3ft. 5-Point Metal...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
