oil pan removal
/ oil pan removal #41
hmm thats so odd. sounds like a plug or re stricter isn't in place. or like bob mentioned maybe something wrong with the gauge or something blocking the flow to the gauge. cuz if you have good flow out of the port it should have enough volume to build pressure. sounds like the oil is going somewhere it shouldnt maybe
/ oil pan removal #42
Yes got a good flow. I am going to see if I can make a short video showing the oil flow coming out of the port and post it.
That would be great. I hope it shows it shooting out. Did you try blocking the flow with your thumb? Never mind.
/ oil pan removal #43
That's what I was thinking originally with the pump's pressure relief stuck partially open, but apparently this pump doesn't have one.
Max, why don't you remove the spring and valve poppet from the filter head to make sure it isn't stuck, or if the spring isn't broken.
/ oil pan removal
Ok I will give that a try. I took a video of the engine running with the mechanical gauge installed then removed the gauge to show the oil flow out the sending unit connection but can’t seem to get uploaded to my reply but will keep trying. Thanks
/ oil pan removal
Ok took out the spring and poppet and still no change
/ oil pan removal #46
/ oil pan removal
I assume Thomas showed you the video I sent him. I may be getting 1 pound of pressure on the mechanical gauge but that is it. I drove it around the yard for a little bit with the valve cover removed and I had some oil (not a lot but some) spitting up on me and the tractor. I am at a loss as to what to do next. The motor runs smooth, doesn't smoke much and I let it run for an hour with no problems. I have a gentleman who wants to by the tractor but I wouldn't want to sell it to him and it not be running right. Is it safe to sell it the way it is? Any suggestions would be greatly appreciated
/ oil pan removal #48
IF, the pump is GOOD (shaft keyway and internal wear), the oil MUST go somewhere.
The pressure come from restriction of the little clearance between crankshaft, camshaft and rocker arm, bearings and bushing.
You can check your mechanical gauge by connecting to an air compressor. Both gauges should show "almost" the same.
Jacques
/ oil pan removal #49
I would NEED to get that oil pump in my hands before driving it around with 1lb of pressure. Also, I would have a hard time sleeping not knowing what the main and rod journals look like.
/ oil pan removal
Ok I needed to hear that. Now I need to find a service dealer as close to me as I can. This work is starting to get well above my knowledge. I live in Northeast Ohio if anyone knows of a reputable dealer please let me know. Thanks
/ oil pan removal
Ok I have been off for awhile so I will update you folks on What I am going to do. No luck with anything I've tried so I am throwing in the towel before I invest any more time. I am going to find a service center that deals in Jinma tractors to get them to fix the tractor before any more harm is done to the engine. I will keep you posted on what is found out to be the trouble.
/ oil pan removal #52
Looked at the engine and found the JD stamp behind the injection pump. Under the manifold I found numbers stamped into the block but no tag (engine has been rebuilt with new block installed). Numbers look to read - 20111008.
A-HA! Who rebuilt the engine?
/ oil pan removal
A diesel mechanic who works on diesel semi's
/ oil pan removal
What do you mean there's a rub? My mechanical terminology and knowledge is limited. Thanks
/ oil pan removal #56
i think he just means that could be the issue. Maybe the rebuilder missed something.
/ oil pan removal #57
Yep. A quote from Hamlet. Literal translation - "That's where the problem could lie". Really has nothing to do with mechanics or engineering. Didn't mean to confuse.
/ oil pan removal #58
Forgive me if this has been brought up already, but has the engine had oil pressure at any time since the rebuild?
Based on your description, it sounds like the oil pump itself is fine, but that an oil passage is open somewhere which is keeping any oil pressure from building. That's not good because it means oil isn't getting everywhere in the engine.
/ oil pan removal
Hello everyone, back again. Thought I would give an update about my tractor. Last week I took my tractor from where I live in Northeast Ohio down to Chesapeake , Va and dropped it off at Ranch Hand Supply for Ronald to find out why I am not getting oil pressure. Talked with Ronald for about a hour and a half explaining what had been done to the tractor to date. I am waiting for him to get back to me after he investigates the issue. When I get an answer I will give another update. Thanks to everyone who has tried to help me with this issue. I am pretty anxious to find out what is wrong.
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2 Horse Trailer (A62613)
2 Horse Trailer...
