Oil pan removal on 2012 max28xl
   / Oil pan removal on 2012 max28xl #1
Drewintoledo
Ohio
LS MT225HE
Trying to help a friend. Says he needs to drop the oil pan but front driveshaft is in the way. He says "it looks like it's in a tube" and he doesn't understand how to drop it.
Any information is apprecaited. Does anyone have a service manual they can pass me?
   / Oil pan removal on 2012 max28xl #2
Did that on my 3016. exact same engine. if i remember right you loosen the clamps on the rubber boot on the front axle then slide it back. should expose the u joints. There is a snap ring or C clip that you remove which then lets you slide the shaft off the stub.
but from the online parts it might be as simple as removing a C ring and slide the collar back then you should be able to remove the whole shaft. might be 2 bolts holding a stabilizer tube...
Thanks for your reply. Here's what my friend wrote when I sent him your infiormation: "Sadly that does not describe my situation my shaft has no rubber boots I'll have to go underneath and have another look at it. I so no boots no snap rings do anything just a tube thanks for the help"
2013 MACK CXU (A52472)
2001 TRIPLE E INDUSTRIES 48X102 TRI-AXLE STEP DECK (A52472)
2001 TRIPLE E...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
