Oil & Fuel oil pan drain plug size
   / oil pan drain plug size #1
SuperChief
Ford 1710, 8N, 600
Trying to find the right drain plug bolt for 1710 Ford Tractor. M12-?, M14-1.50??. Doesn't appear stripped so probanbly don't need oversize.
Thanks, is that an online catalog?
   / oil pan drain plug size #4
Does it have the sealing washer on it? There should be a special washer with a rubber insert. Will be dry as a bone if you put a new washer on it.
DON'T over tighten it, it will destroy the rubber seal and it will leak again.
   / oil pan drain plug size #5
Might just find a copper washer that fits the plug from Hardware store, most carry some. Mine never leaked without a washer and I just have it guttentight and not a skosh more.:laughing:
Thanx to all. New one from o'reilly's came with a nylon washer. will keep an eye on it.
   / oil pan drain plug size #7
The people on this site are drain plug experts. Nothing is beyond our scope. :thumbsup:
