Torx
Bronze Member
Hello from a New User here.
I recently noticed a large amount of oil coming from the rear drain hole on the bottom of the starter motor on my YM195. This is a recent purchase and I got a great deal and want to fix this problem asap, but have become stumped as to what to do next.
It leaks a lot of oil until it gets down to the 1/3 level on the dipstick then slow to a trickle but 2 1/2 quarts in an hour is rough on the wallet and on the grass and carport as well. Too big of a leak to try to fix with an oil stop leak additive.
I pulled the starter motor and see nothing obvious. The clutch housing isn't full of oil or anything like that. The starter motor does have two obviously milled into the motor during it's manufacturing process, fluid drain holes. The oil is fairly hemorrhaging much like a severed artery when I changed the oil and filter. It leaks worse when I go downhill but that could be due to the fact that the forward drain hole comes in starter drain hole comes into play. The leak slows somewhat as the oil level is pumped down to less than half a gallon.
There are no holes in the engine housing and I see no oil coming from the bolt holes or around the gasket of the starter motor. Also I don't notice any oil leaking from the small gap created by the junction of the engine and clutch housing.
I carefully replaced the starter and made double sure that the gasket was in good shape and that the bolts were torqued back to proper tightness. The oil is only leaking from the holes in the starter motor and nowhere else. The radiator doesn't leak a drop in spite of it's age so over-filling of the oil is not the issue here. I don't have any way to gauge the oil pressure of compression but the tractor starts easily and runs fairly well despite gushing oil enough to interest small Middle Eastern nations looking for fresh sources of oil. {trying to laugh about this}
My next troubleshooting task will be to start the tractor and remove the starter or remove the starter and pull the tractor till it does start. I don't know what this will show me but failing some grand revelation I will be returning the mower to the original owner in hopes that he has a good heart and will refund my money or get it working properly. I am new to Yanmar tractors but fell in love with the brand after driving a friend of mines 37 year old restored tractor.
Any help from you nice folks would be greatly appreciated and I do have some pictures of the starter in place and plan on taking pictures of the underside of the starter after I remove it again in case nobody believes in drain holes on original equipment starter motors.
Thanks in advance,
Torx the Orx
Thanks in advance,
Torx the Orx
