Oil & Fuel oil in Kubota B2630
/ oil in Kubota B2630 #1
BCNU
Hopkinsville,KY
Kubota B2630
Dose anyone know what weight engine oil was put in a B2630 from the factory ? I bought my tractor back last april and it only has 18 hours on it but I want to change it anyway for this spring. My owners manual calls for SAE 10W-30 or 10W-40 or a straight 30 weight for temps over 77 degrees. I use schaeffer oil products and my Rep told me I could run a 15W-40 and I would be fine but being engine is under warranty and I don't want any hassles in case something were to happen. Is anyone here using a straight 30w in there engine ? If i could run the 15W-40 I would like to as, where my father works they buy it in bulk and I can get a good deal on it. So what weight engine oil are you guys with the 2630 0r 3030 running in your tractors?Thanks in advance for any info !
/ oil in Kubota B2630 #2
Your tractor probably came with 10W-30, but not from the factory. The tractors are shipped over disassembled in crates and put together at the dealer (maybe distributor). 15W-40 should be just fine, although it is probably a bit heavier than I'd suggest in a new tractor in cold weather. Didn't see where you are... But as far as warranty stuff goes, how in the world will they know what weight oil you put in it?
/ oil in Kubota B2630 #3
Im running the 10W-30 factory oil in it until my first change at 50 hrs...and then switching to a 5W-40 syn oil.
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
2500 GALLON WATER TANK W/RELEASE VALVE (A60430)
2500 GALLON WATER...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
