oil furnace sooting extensively
   / oil furnace sooting extensively #1
paulmars
None
In December 2023 I noticed lottsa smoke coming from my furnace. I live in florida, so dont use it too much. I did a smoke test and draft check january 2023 and all was good.
It was still heating house fine.
Many years ago I started doing my own maintenance/tune ups because I could not find anyone in florida to do it right. Even the guy who installed it didnt set it up properly. So, I check smoke and draft at least once a year. I change filter at every take fill. Strainer, nozzle and electrodes (yes I adj them too) every year or two. There are a few other parts that Ive changed as called for in the maintenance manual, that I cant remember right now. I also got the proper specs from the manufactures. One service guy actually came with a later revised spec for a later model and some specs were different. I confirmed with the manufacturer that those specs were wrong for my model year. He also didnt check draft. I can post that letter.
Anyway Im having doubts about my tuning ability, so I again looked for someone qualified. I contacted over 70 HVAC service companies in my and neighboring counties in the past two weeks. I found no one. Many said they could, but when asked how they adj co or stack temp, then didnt know.
Last week I scrubbed out then chamber, heat exchangers, sight tubes, flue, and chimney. Whatta mess! Then I changed the nozzle which was less then 2 years old (it was dripping oil and Ive never seen that before) and even though it looked fine, I changed the pump strainer too.
Im going to order a pressure gauge to hook up permanently to the pump, to check and monitor the pressure which Ive never checked. Suggestions for a good accurate brand?
Any ideas why it was smoking so much?
tks,
paul
   / oil furnace sooting extensively #2
I had that problem and it turned out to be a faulty pressure regulator. I think it was $70.00 plus the labor. No problems since then. That's the sort of thing i like to leave to professionals. I try not to mess with systems that can cost me more if I poke around in them. NOSHOK is the brand I use for Hyd. pressure gauges.
   / oil furnace sooting extensively #3
As @TBob42 suggests, my bet is your pressure regulator, or perhaps a check valve.
You might ask your oil supplier for recommendations.
All the best,
Peter
   / oil furnace sooting extensively #4
Another reason for excessive smoke can be a restriction in the air supply. I( have had webs inside an air intake cause me problems by restricting air.
Eric
   / oil furnace sooting extensively #5
As soon as i choose a pressure gauge ill ck that and shutoff.
   / oil furnace sooting extensively #7
You can also retrofit your burner with a solenoid for a fuel shut off, for a cleaner shutdown. On most burners when it losses the call for heat and shuts down the burner motor it has some slow down time which does result in a bit of fuel supplied at a lower pressure and often no ignition at that point. It is usually just a few drops as the pump restriction and load stops the blower/pump motor fairly quickly.
Because of clearance issues ill need a 4' tube between the pressure guage and pump. How do i get the air out of that?
   / oil furnace sooting extensively #9
You could carefully pour oil into the hose after it's hooked up at the pump end. Alternatively you could loosen the gauge a bit carefully with the burner running to bleed the air out.
It doesn't need to be bleed completely a bit of air will act as a pulsation dampener from the pump pulsations.
Or you can get fancy and put a tee at a high point and reduce down to install a bleeder valve,
   / oil furnace sooting extensively #10
Nozzles were always the first thing to check on my previous boilers. Good fuel oil technicians are getting very rare! Still lots in use residentially in New England, but here and further south, good luck.
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
2012 Buick Enclave Premium SUV (A53117)
2012 Buick Enclave...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2011 Chevrolet Suburban SUV (A51694)
2011 Chevrolet...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
