Oil & Fuel Oil from overflow hose b6200d
   / Oil from overflow hose b6200d
Other than the pump, what are the possible entry points for hyd oil into lube oil? The pump is the only point.....isn't it?.........................Mike
that's what I thought but I can't believe the seal went bad this quickly. I guess it's time to take the pump off again.
   / Oil from overflow hose b6200d #22
Possible you put the seals in backward? Not hard to do if you don't realize................M
How can you tell if you have diesel fuel leaking into the oil by looking at the oil? Does diesel separate from oil? How about hydraulic fluid?
   / Oil from overflow hose b6200d #25
Assuming this is the only path for hydraulic oil into the crankcase, the possibilities are the seal was installed backward, the seal lip was rolled or cut on installation, or maybe the bushing in the pump is worn to the point the seal can't hold it. The lip on the seal should be facing the pump, making it harder to install. If there are splines or a keyway on the shaft that could cut the lip, some black electricians tape wrapped on the shaft will protect the seal as it is slid onto the shaft. The lip of the seal and the surface it rides on needs to be lubed when installed. Was there a groove worn in the shaft where the seal was riding? If you go back into the pump to replace the seal again, take some pictures and post them.
UNUSED PABREAK PC463 - 72" HYD PLATE COMPACTOR (A57193)
UNUSED PABREAK...
BFH 1000 BALANCE FORCE HARMONICS TIRE BALANCER (A54757)
BFH 1000 BALANCE...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52707)
2020 CATERPILLAR...
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
