Backhoe Oil for backhoe ?
/ Oil for backhoe ? #1
wanasrx
NY
Kioti 3054
I have a kb80 hoe, manual says to use 10w40 w/"sd" rating, can I use rotella t 15w40?
Rich
/ Oil for backhoe ? #2
What is a kb80?
Do you mean a kioti kb2385.
/ Oil for backhoe ?
It's a Kioti subframe mounted Backhoe. Model KB80
/ Oil for backhoe ? #4
</font><font color="blue" class="small">( It's a Kioti subframe mounted Backhoe. Model KB80 )</font>
Never heard of it.
Also don't recall ever seeing it listed on the Kioti website or sales fliers
/ Oil for backhoe ? #5
Wallace - Its an older model Kioti hoe... I acutally have a part manual for it.... Its a very old hoe...
wanasrx - I wouldn't waste the money for Rotella-T just use an engine oil 10w40. Our skid loaders use an engine 10w-30 for its hyd oil.
/ Oil for backhoe ?
Thanks Jon
Rich(wanasrx)
/ Oil for backhoe ? #7
I would use either the motor oil or use the same hydro oil you use in your tractor.
That backhoe is definitely old.
/ Oil for backhoe ?
What does everyone use for hyd. oil?
How old do you think it is?(she still seems to work good) The tractor can't be older than a 93' , yes?
/ Oil for backhoe ? #9
Give a serial # and we can see if Kioti has it on file.
/ Oil for backhoe ? #10
If you BH has motor oil in it now I would keep using a motor oil in it.
As far as the tractor we use a high quality UTF "Universal Tractor Fluid" that is rated for both hyd and transmissions. We use Allied brand fluids here only because we are a dealer for them. There are alot of good brands out there though.
What model tractor and loader do you have?
/ Oil for backhoe ?
Jon,
3054 w/122 loader.
I'll be back later with the serial #.
Thank You
Rich
/ Oil for backhoe ? #12
I happen to have an owners manual for a KL122 and it is dated 1987.... So I would almost bet your tractor will be around that year too...
/ Oil for backhoe ?
Serial # 26500221
engine- 312700368
loader-32542
hoe-49499?
2018 GMC Terrain AWD SUV (A66738)
2018 GMC Terrain...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
Flail Mower
Flail Mower
PRESSURE WASHER (CONDITION UNKNOWN) (A68842)
PRESSURE WASHER...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
