Backhoe Oil for backhoe ?
/ Oil for backhoe ? #1
wanasrx
NY
Kioti 3054
I have a kb80 hoe, manual says to use 10w40 w/"sd" rating, can I use rotella t 15w40?
Rich
/ Oil for backhoe ? #2
What is a kb80?
Do you mean a kioti kb2385.
/ Oil for backhoe ?
It's a Kioti subframe mounted Backhoe. Model KB80
/ Oil for backhoe ? #4
</font><font color="blue" class="small">( It's a Kioti subframe mounted Backhoe. Model KB80 )</font>
Never heard of it.
Also don't recall ever seeing it listed on the Kioti website or sales fliers
/ Oil for backhoe ? #5
Wallace - Its an older model Kioti hoe... I acutally have a part manual for it.... Its a very old hoe...
wanasrx - I wouldn't waste the money for Rotella-T just use an engine oil 10w40. Our skid loaders use an engine 10w-30 for its hyd oil.
/ Oil for backhoe ?
Thanks Jon
Rich(wanasrx)
/ Oil for backhoe ? #7
I would use either the motor oil or use the same hydro oil you use in your tractor.
That backhoe is definitely old.
/ Oil for backhoe ?
What does everyone use for hyd. oil?
How old do you think it is?(she still seems to work good) The tractor can't be older than a 93' , yes?
/ Oil for backhoe ? #9
Give a serial # and we can see if Kioti has it on file.
/ Oil for backhoe ? #10
If you BH has motor oil in it now I would keep using a motor oil in it.
As far as the tractor we use a high quality UTF "Universal Tractor Fluid" that is rated for both hyd and transmissions. We use Allied brand fluids here only because we are a dealer for them. There are alot of good brands out there though.
What model tractor and loader do you have?
/ Oil for backhoe ?
Jon,
3054 w/122 loader.
I'll be back later with the serial #.
Thank You
Rich
/ Oil for backhoe ? #12
I happen to have an owners manual for a KL122 and it is dated 1987.... So I would almost bet your tractor will be around that year too...
/ Oil for backhoe ?
Serial # 26500221
engine- 312700368
loader-32542
hoe-49499?
Front Tank Bracket (A64126)
Front Tank Bracket...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2018 Rotary SM18N001 18,000lb. Hydraulic 4-Post Auto Lift (A66736)
2018 Rotary...
More info coming soon. (A64557)
More info coming...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
