Oil & Fuel Oil filters
/ Oil filters #1
Bob O
I posted a question about my LS 4540 tractor and where to get oil filters etc. about ten days ago and got one response. Disappointing at best. I still have some questions. Upon looking up a suggested filter crossreference web site and coming up with an oil filter that should have worked on my tractor I had three different brands of filter sent to my auto shop on Sat. morning and not one would fit. The threaded stub sticking out of the side of the engine block is too short to reach any of the threads in any of the filters. The only filter that will thread on is the one from Montana and the dealer sells that filter which seems of no special quality for 17.99 when the crossreferenced filter in a Wix product costs me 3.50. What a rip off.
This leads me back to my first and still unanswered question. Is my LS4540 tractor the same as the 4540 tractors already talked about on this web site. If it is the same has anyone experienced this problem and what did you do about it?
After spending a frustrating weekend servicing my tractor I now have another question. What type of fluid is supposed to go in the rear brake drum portion of the rear axle. The manual in not clear and the dealer recommended multi-purpose hydralic fluid even though the fluid that came out of the drum area was very heavy gear oil.
Hope to hear something on these things soon. Special thanks in advance to anyone who responds.
Bob O
/ Oil filters #2
Did you try the Donaldson P550162?
Maka
/ Oil filters
I have not tried the Donaldson filter yet but I will try to find some. Thanks for the suggestion. Bob O
/ Oil filters #4
i'm suffering similar filter problemswith my 3040....thought i had it figured out with the website cross reference...turns out nobody stocks the one I need for hydraulics.......got it straightened out last week.
I am also curious about the gear oil in the rear axle outer housings....It seemed like sae 80 gear oil to me. The manual refers to this but also indicates trans/hyd (TDH?)oil is acceptable for the whole rear axle / trans /hydraulics..
help?
/ Oil filters
What number did you come up with for the hydralic filter. Bob O
/ Oil filters #6
for my application (3040) I needed a Luber Finer LFH8207
I was also able to get numbers for AC Delco and WIX...but could not track down the filters. If I still have the numbers writte down, I'll post them tomorrow
/ Oil filters #7
I have used Donaldson p550162 and Napa 1334 oil filters on my 4540. They both fit fine.
/ Oil filters #8
I cannot confirm the compatabilty...but here are the numbers I was given for hydraulic filters for a 3040
filter diameter =4.282"
gasket diameter = 3.967 od, 3.587 id
threads = 40x2mm (roughly 1 1/2" dia)
WIX - 51715
AC Delco - PF1621
GM - 89034949
Luber Finer - LFH8207
/ Oil filters #9
I found the attached on tractorbynet about one year ago. Don't know if it is accurate, don't know why it wouldn't be.
Just this week I have been working with Ken from Earthmovers Supply to buy new filters (hydro, oil, fuel, air) for my tractor. I found Ken on an old thread here and found him very helpful this week as I was putting together my order. In his original thread, he wrote ... My company ... EARTHMOVERS SUPPLY, INC. - Parts Distributor For Off-Road Equipment ... is a stocking distributor for The Donaldson Co.
I will let you know how smoothly the actual purchase and delivery goes.
  • tractor_filters[1].pdf
/ Oil filters #10
citytransplant said:
Just this week I have been working with Ken from Earthmovers Supply to buy new filters (hydro, oil, fuel, air) for my tractor. I found Ken on an old thread here and found him very helpful this week as I was putting together my order ...
Received my order of new filters recently ... transaction went smooth as silk.
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
VR59 Hydraulic Vibratory Roller Skid Steer Attachment (A59228)
VR59 Hydraulic...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
