Oil & Fuel OIl Filter
/ OIl Filter #1
jethroish
Scottsburg, IN
RK55S, CC EX3200
Doing my first oil change on EX3200 today. Did a filter look up on Wix then crossed it over to a Bosch (O'Reilly's had Bosch on sale). Came up with Bosch 3312 oil filter. Anyone know if this is correct? When I change it, I will do a close inspection. Oddly, this filter is used for 1982? Hondas.
/ OIl Filter #2
Its pretty close, the thread matches up. Here's some specs, I found more information on the Wix/Napa Filter:
BOSCH Part # 3312
Outside Diameter: 3.15"
Thread M20X1.5;
Wix 51334 & Napa 1334 Oil Filter
Principal Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-09), Hyundai (89-10), Isuzu (85-04), Kia (01-10), Mercury (87-91), Mitsubishi (89-98), Subaru (87-10) Atlas-Copco, Case, John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel, Other
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
(This information from Wix Filters & NapaGold Filters: FleetFilter Secure Online Store)
/ OIl Filter
Thanks for the specs. The rubber gasket matched up. The original filter had 5 holes around the top, the bosch had ( I think it was) 7. Aside from that, the Bosch is about 1/4 inch shorter.
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
QA Pallet Forks (A64127)
QA Pallet Forks...
