Oil & Fuel oil filter number
/ oil filter number #1
rottonrob
North Idaho
tym 233HST
Hello,
Just bought a used t233hst and need to know the napa or wix or some common oil filter number...Thanks
/ oil filter number #2
Rob,
I just googled the TYM part number and oil filter and came up with some name brand alternatives for my T353HST. Jordan Sales in Post Falls has always been a good source of info for me. Buy a replacement from them and ask them about equivalent/cheaper filters.
/ oil filter number
Thanks,
I crossed at NAPA and came up with a 1358 filter...
/ oil filter number #4
i have a 353HST also......what did you find ?
my local TYM dealer went out of business 3 years ago, so i have ordered from dealers in other states, but Local would Be great.
also, what engine oil did you use for your 353 ??
thanks
bob
/ oil filter number #5
thanks
bob
Bob,
Here is the info I found for my 353;
TYM FILTERS
OIL
Donaldson – P502067 Original Part ($ 15.41) Dealer
• Fleetguard – LF 3925
• Baldwin - B 1400
• Fram – PH 6607 or 6017A
• WIX – 57040 or 51365
Hydraulic
Donaldson – P169078 Original Part ($43.00) Dealer
• Fleetguard – HF 35006
• Baldwin – BT 8416
• Fram – P 7537
• Wix – 51586
AIR
Donaldson – Outer - P8121575
Inner - P822858
I will check on what oil I used and get back to you.
/ oil filter number #6
THANKS---I FOUND THIS
LUBE SPIN-ON FULL FLOW
Primary Application NISSAN, MAZDA, MITSUBISHI
Alternative parts
Bar Code 74233010989
Sizes C - Length: MM 65
B - Thread Size: N/A M20 x 1.5
D - Gasket OD: MM 65
E - Gasket ID: MM 56
Efficiency Beta 2: Micron 20
Relief Valve Setting: Bar 0.80-1.00
Weight: Kgs 0.20
Cube: Cubic Meters 0.00
A - OD: MM 68
Cross Reference AC: PF1237, PF2112, PF2135 - ALCO: SP1001, SP1002 - AMC: L6607, MO6607, OC14090, OC15180, OC16090, OF2021, SFO4621, VO54, Y1193053150, Y11930535150 - AMS/OIL: EAO12, SDF13 - ASAHI: 11K, 526K, FO011A, MO256 - ATLAS: M33 - BALDWIN: B1400 - BIG A: 92358, 92365 - BLACKROCK: 1090007 - BOBCAT-MELROE: 6671057 - BOMAG: 5740096 - BOSCH: 3300, 72180, 72182 - CARQUEST: 85365 - CHAMP: PH2876 - CHAMPION LABORATORIES: PH2868, PH2876, PH7015, PH7028 - CHARLES MACHINE: 194691, 452410 - CLEAN: DO854, PO6607 - COOPERS: Z1039 - CROSLAND: 2151 - DANIEL DOYEN: DOF4901 - DEUSCH: D371 - EXMAN: L6607, MO6607, OC14090, OC15180, OC16090, OF2021, SFO4621, VO54, Y1193053150, Y11930535150 - FEDERAL MOTORS: FMS1809, FMS2046 - FIAAM: FT5406 - FIRESTONE: TF4622 - FLEETGUARD: LF3692, LF3925 - FLEETRITE: LFR83692 - FORD: E9GZ6731A - FRAM: DG6607, PF9715, PH2876, PH4998, PH6017, PH6017A, PH6607, PH9715, TG6607 - FSA: FO1033 - GM: 25014422, 25171946 - GOODYEAR: L4622 - GREYFRIARS: 9034S - GROUP 7: V4612, V4622 - GUD: Z222 - HASTINGS: LF113 - HINO: 156072110 - HONDA: 15400PFB004, 15400PH3004, 15400PJ7005, 15400PJ7015, 15410MCJ000, 15410MCJ003, 15410MM9013, 15410MM9405 - HYUNDAI: 263002Y500 - INGERSOLL RAND: 85426849 - JACOBSEN TEXTRON: 5002644 - JOHN DEERE: M806418 - KAWASAKI: 160971063, 160971072 - KIA: 2630002500, 263002Y500, B63114302, FE3R14302, OFE3R14302 - KNECHT: OC195 - KOBELCO: 11930535150 - KOMATSU: 11930535150, 1930535151, YM11930535150 - KRALINATOR: L265, L266, L358 - KUBOTA: 1585332430, 1585399170, 1585399179, HH15032430 - LEE ENGINEERING: LF2868 - LONG: A0653039 - LUBER-FINER: PH2876, PH7028 - MANN & HUMMEL: W671, W6780 - MAZDA: ADM52106E, B63014302, B63114302, B65114302, B6Y114302, B6Y114302A, B6Y123302, B6Y214302, B6YL14302, F2Y014302 - MICROPORE: T600 - MITSUBISHI: 30A4000200, 30A4000201, 30A4000202, MD134593, MD134953 - MOBIL OIL: MO4612, MO4622 - MOPAR: F0PH2868, F0PH2876 - MOTORCRAFT: FL816 - NAPA: 1365, 21365 - NIPPON: J1317004, MTW61, T59 - NISSAN: 1520865F00, 1520865F01, 15208HC010, 15208KA000, 15208KA010 - PENNZOIL: PZ37 - PERKINS GREAT LAKES: 102619 - PHILLIPS 66: PO1357, PO1365, WO1365 - POLARIS: 3084963 - POWER-FLO: SL14612, SL14622 - PRO-TEC: 168 - PURFLUX: LS892 - PUROLATOR: L14612, L14622, ML16817, ML16819, PER4622, PL14612, PL14622 - QUAKER STATE: QS14612, QS6607 - REPLACED BY: P550641 - SAAB: 32005769 - SAKURA: C1809, C18093, C18094, C18096 - SDMO: 330560538 - SHELL: S58, SH531, SH538 - SOFIMA: S3258R - STP: S6607 - SUBARU: 15208AA024, 15208AA080, 15208AA09A, 15208AA100, 15208KA000, 15208KA010 - SUNOCO: O37 - SURE FILTER: SFO4612 - TEHO: 4189 - TEXACO: HSO134, TFC531 - TORO: 934295 - TOYOTA: 1560187703 - UFI: 092325840, 2325800, 2325840 - UNION 76: PF1365 - UNION CITY BODY: C431, C830 - UNIVERSAL: C431, C830 - VIC: C806, C901 - VMC: LF502067 - WARNER & SWASEY: PH2868, PH2876, PH7015, WPH2876, WPH7015, WPH7028 - WIPAC: CA151, CA168 - WIX: 51365 - WOODGATE: WGL9056, WGL9197 - YAMAHA: 3FV1344000, 5GH1344000 - YANMAR: 11930535150
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
2021 CATERPILLAR 308CR EXCAVATOR (A65056)
2021 CATERPILLAR...
55 GALLON CONTAINERS OF FLUIDS QTY OF 6 (A68842)
55 GALLON...
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
TOTE OF ROAD SIGNS AND TWIST LOCKS (A68842)
TOTE OF ROAD SIGNS...
