Oil & Fuel oil filter ID Help ?
/ oil filter ID Help ? #1
Slopoke_iii
alabama
Yanmar ym270
I have yanmar ym270 tractor. And yes it is definately a ym270. It has a cartridge type oil filter in it. I have no parts numbers and can't find it anywhere even at local john deere dealer. Does anyone have any idea what cartridge it might use or how i can change it to a spin on filter of some sort ?
thanks
slopoke_iii
/ oil filter ID Help ? #3
When I had 180D and 220D Red Yanmars, I found that Mazda car & truck oil filters were interchangable with the Yanmar parts.
/ oil filter ID Help ? #4
Try taking it to Napa or a parts store that sells Wix filters.
/ oil filter ID Help ? #5
I second this advice. In the back of the Wix master catalog is a filter size spec guide. One can match the diagrams and measurements to arrive at the right
size. Provided the counterperson can read you should be good.
I tried their web site but the spec guide isn't on there.
/ oil filter ID Help ? #6
size.
We hear this all the time from folks who seem to assume that if a filter is the same (or similar) in size to the original and it will thread on, it must be right. There are other factors that can't be measured this way....presence or lack of an anti-drain valve, pressure setting on same, micron size of filter material, flow rate/capacity of the filter. It is prudent to make sure these things match up unless a filter is specifically listed for your tractor application by the filter manufacturer.
/ oil filter ID Help ? #8
LMTC said:
[re Wix filters, a reputable brand]... seem to assume that if a filter is the same (or similar) in size to the original and it will thread on, it must be right. There are other factors that can't be measured this way....presence or lack of an anti-drain valve, pressure setting on same, micron size of filter material, flow rate/capacity of the filter.
In an ideal world, sure. But - if the user is going to use the compression release until the oil light goes out, then drainback won't be very important. Likewise an automotive-sized filter should have adequate flow capacity for these 1200cc or less engines in the smaller tractors. Seems to me micron size of an oil filter might correspond to the reputation of the mfr, but a quality automotive filter should be a good-enough match assuming regular maintenance intervals and quality oil. I see one seller of filters for Yanmar calls it a '1334'. ( A common filter # for Honda etc). What am I missing? What is the magic that makes an OEM or replica filter better?
/ oil filter ID Help ? #9
The master catalog lists all those specs as well, but since he has none of that to go on I didn't include it.
Thanks guys for all the help and suggestions. I did as suggested and went to oreilly's auto parts and the guy there used the wix filter guide to match me up with a cartridge that works like a charm !
Thanks again
Slopoke_iii
/ oil filter ID Help ? #11
Funny I work for them too...
Now, so you don't have to do that again, rip off the lid of the filter box and poke it in the manual or just write it on the tractor somewhere out of the sun. Tool box lid works pretty good.
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2016 Chevrolet Tahoe Multipurpose Vehicle (MPV), VIN # 1GNLCDEC0GR387273 (A66738)
2016 Chevrolet...
1143 (A63745)
1143 (A63745)
2024 CATERPILLAR 239D3 SKID STEER (A65056)
2024 CATERPILLAR...
2004 Johnson 70hp 4-stroke Outboard Boat Motor (A66738)
2004 Johnson 70hp...
2011 SHBO MANIFOLD TRAILER (A67714)
2011 SHBO MANIFOLD...
