Oil & Fuel Oil Drain Valve
/ Oil Drain Valve #1
SpringHollow
Elite Member
South of Rochester, NY
Power Trac 1850, NH 2120
On my PT, the oil drain plug does not come close to the drain hole and makes a major mess when doing oil changes.
Particularly since our drain plugs are protected, I ordered a drain valve from Qwikvalve.
:: QwikValve::FUMOTO OIL DRAIN VALVE::The best way to change your motor oil without tools or mess!
i ordered the type with the nipple on it for hooking it up to a hose.
Nice site. I had measured my drain plug with calipers and knew it was 18 mm but it was nice that the site has a search engine that works quite well and confirmed the size.
Seems like a nice solution for us.
Ken
/ Oil Drain Valve #2
I have a similar valve on my dodge/cummins pickup that was made by Femco ( FEMCO Draintechnology, responsible oil draining ) that i really love it makes oil changes so easy. the Femco protrudes less, but has a cover cap that must be removed and you must have tube to drain the oil .. At one time they had a similar valve as the QwikValve, but I was always worried about tripping the lever accidently by driving over something..
I have not seen the QwikValves, but am seriously thinking about putting something similar on my tractor and my wifes car
Brian
/ Oil Drain Valve #3
Ken
Have you checked to see if maybe you might have two oil drain holes for your motor, one on each side of the engine? My kohler command pro 25 has two and like you said one of them don't line up with the holes in the tub and would cause a mess if I used that one but the other one lines up alright.
/ Oil Drain Valve
Maybe there is a drain plug underneath that i missed. Even if there is, this will be a nice solution.
Ken
/ Oil Drain Valve #5
I've been using the Fumoto valve for years on several cars and am very happy. It's a quality product. Oil changes are quick, you never drop the drain plug in the waste oil pan and you'll never strip a drain plug.
/ Oil Drain Valve
There is a bottom drain plug as well as the one on the side. The one on the very bottom does not line up with the hole in the "tub" which is why i missed it.
Ken
BUYERS PREMIUM & PAYMENT TERMS (A59911)
BUYERS PREMIUM &...
2007 Toyota RAV4 SUV (A61574)
2007 Toyota RAV4...
12-16.5NHS Skid Steer Wheels and Tires (A61572)
12-16.5NHS Skid...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
John Deere Front & Rear Rims (A64119)
John Deere Front &...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
