Oil Drain Plug
   / Oil Drain Plug #1
cjmt29
Pulaski, TN
2013 Workmaster 75
So, I know this is a pretty dumb question, but...where is the oil drain plug on a Workmaster 75. Doing the 50 hour maintenance and got started in dark. I cannot fine the drain plug, though. Any help is appreciated. Thanks.
   / Oil Drain Plug
One in every crowd. I looked there, but the pic wasn't any help.
   / Oil Drain Plug #4
Just a guess, but I think it's item #5 in the image below.
Steve
   / Oil Drain Plug
Thanks. I'll give it a try this afternoon. I guess I was looking for a bolt instead. There is a plug just like that one on other side too. Thanks, again.
   / Oil Drain Plug #6
It's hard to tell from the diagram, but it looks like the Workmaster drain plug has a hex drive head. FWIW, the hex drive head on my TN 55's drain plug is 12mm.
Steve
   / Oil Drain Plug
Thanks a bunch, brother. Mine was probably a 12mm too, but I used a T60. Couldn't find a 12mm anywhere. Thanks, again.---Craig
   / Oil Drain Plug #8
Sears has a 12mm hex key: Sears.com.
You can make a workable driver using a bolt with a 12mm hex head and two nuts (one acting as a jam nut).
Steve
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A53472)
Heavy-Duty...
2012 Dodge Charger Passenger Car (A51694)
2012 Dodge Charger...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2021 John Deere 410L Backhoe (A53342)
2021 John Deere...
1265 (A50490)
1265 (A50490)
FRIGIDAIRE 24,000 BTU WINDOW AC UNIT (A51248)
FRIGIDAIRE 24,000...
