Oil Drain Plug
   / Oil Drain Plug #1
cjmt29
Pulaski, TN
2013 Workmaster 75
So, I know this is a pretty dumb question, but...where is the oil drain plug on a Workmaster 75. Doing the 50 hour maintenance and got started in dark. I cannot fine the drain plug, though. Any help is appreciated. Thanks.
   / Oil Drain Plug
One in every crowd. I looked there, but the pic wasn't any help.
   / Oil Drain Plug #4
Just a guess, but I think it's item #5 in the image below.
Steve
   / Oil Drain Plug
Thanks. I'll give it a try this afternoon. I guess I was looking for a bolt instead. There is a plug just like that one on other side too. Thanks, again.
   / Oil Drain Plug #6
It's hard to tell from the diagram, but it looks like the Workmaster drain plug has a hex drive head. FWIW, the hex drive head on my TN 55's drain plug is 12mm.
Steve
   / Oil Drain Plug
Thanks a bunch, brother. Mine was probably a 12mm too, but I used a T60. Couldn't find a 12mm anywhere. Thanks, again.---Craig
   / Oil Drain Plug #8
Sears has a 12mm hex key: Sears.com.
You can make a workable driver using a bolt with a 12mm hex head and two nuts (one acting as a jam nut).
Steve
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
10' CONTAINER (A51248)
UNUSED RAYTREE RMSG29-29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
