Oil & Fuel Oil Drain plug ? 5083E
   / Oil Drain plug ? 5083E #1
wideurt
Time to change the oil. The drain plug takes a square male socket. 3/8 driver is to small. Does anyone know what size this is Thanks
   / Oil Drain plug ? 5083E #3
Have you tried a 1/2" drive?
   / Oil Drain plug ? 5083E #4
Went to JDparts catalog and the plug part number is R515195. Went to part detail looked up the part and the following specs where provided.
I second WilliamBos post indicating 10mm
English Metric Specification
Weight 0.09 LBS 0.04 Kg
Thread Diameter 22.000 MM
Thread Pitch 1.500 UNITY
Drive Size 10.000 MM
Length 10.000 MM
Length 13.000 MM
Diameter 30.000 MM
Drive Type SQSCH
   / Oil Drain plug ? 5083E #5
A 1/2" square drive works on my JD 5225 engine-oil drain plug.
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
