Oil cooler tip
   / Oil cooler tip #1
CO_Farmer
Loveland, Colorado
Yanmar YM2500
I want to pass along that I recently installed a Perma-Cool #69189 universal oil cooler on my YM2500 and that it fits and works fine (with a minor modification). One benefit is that using the kit lets you use common oil filters with a standard Toyota/Ford 3/4" thread. I'm using the shorter Bosch 3330 filter with my kit because of clearance issues with the power steering cylinder.
The kit includes a screw-on adapter sleeve that transitions the Yanmar filter nipple to the new size that needs to be shortened by 1/4" using a hacksaw and vise. A trial assembly of the cooler adapter to the engine block will make the modification clear.
The cooler itself fits right in front of the tractor's radiator with no problem.
Perma-Cool also makes a #69195 cooler kit that lets you move the filter to another location. Doing that would let you use an even larger oil filter like the common V8 Ford PH-8A or Bosch 3422.
I will say that my tractor runs a *lot* cooler with the added oil cooler when I'm pushing it to the limit when grading our road.
Being able to use more common oil filters was a bonus.
   / Oil cooler tip #2
That's a pretty cool add on. Got any pictures??
   / Oil cooler tip
I'll take some pix in a few days after the weather cooperates.
2012 Peterbilt 388 Sleeper Truck Tractor (A53117)
2012 Peterbilt 388...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2008 Toyota Tundra Crew Cab Pickup Truck (A51692)
2008 Toyota Tundra...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
