Oil & Fuel Oil coming from valve cover breather
   / Oil coming from valve cover breather
Short and stubby filter vs tall filter in height. That is all.
Yanmar engines will work better and last longer on 10W30. We've hit this topic so much in both the compact Deere sub-forum and the Yanmar sub-forum over the years here and elsewhere.
What about synthetic, I dont like it because once you use it, you cant go back to regular as the engine becomes accustomed to it, much like regular versus high octane for gas.
   / Oil coming from valve cover breather #12
Its a diesel not a gasser engine, I do a blend of more dino oil in the summer and then switch to more synthetic in the winter.
Synthetic is derived from Natural Gas. The molecules are more consistent in size.
Dino is made from crude oil. The molecules are of various size.
In tight tolerance places in the engine, the dino oil will get in there with no troubles. The synthetic will get as near as it could. So dino wins that game. Synthetic can keep the engine heat in check way better due to it's normal molecule size.
There are pros/cons to each.
People use synthetic blends. That is synthetic mixed with dino. So there are no issues going back and forth.
IF you go with a blend, then blend it yourself. Why? Pick up ANY brand of blend oil and find the mixture ratio. NOBODY shows it. A person would guess 50/50. No way. 60/40? Not even close. The blend bottles at the store are 80% dino and 20% synthetic at best. Buy 1-dino to 1-syn and blend it together for 50/50.
For a diesel a BLEND works the best. Diesels have longer strokes and no spark. Synthetic helps with reaching the upper part of the engine and the dino helps in the lower end of the engine. Both in movement satisfy the needs of a diesel engine in harmony.
Too much hype and marketing tactics. The diesel people on the oil forums are the most knowledgeable over the car nuts.
   / Oil coming from valve cover breather #13
Oil discussions, Bob the Oil Guy used to keep us straight and provide good information.
   / Oil coming from valve cover breather #14
Old wives tale and complete nonsense.
The story started because some old Big Block Chevys didn't like it. Long and boring story.
Today's machining process is far advanced from the 60's. Switch back and forth as mush as you want. Personally, I wouldn't bother. Just use a good syn and head on down the road. If you need to top it off with some dino oil, go for it. Just try to use the same weight, if possible. Even then, it's not the end of the world.
   / Oil coming from valve cover breather #15
Oh, yes I was the proud owner of a 1974 Caprice Classic with a 454 cu inch engine. Every one thousand miles, open the hood and pour in a quart. Being driving along and a lifter would collapse.
The first time it happen I pulled into a full service, service Station (those days are long gone) A young gentleman came out and asked what I needed and I asked him if he had any idea about what the noise was. He raised the hood, pulled a screwdriver out of his pocket leaned over and placed it on the right valve cover. Raised back up and said a lifter has collapsed on the right bank, happens with the 454 because of the strong valve spring pressure. Since the vehicle only had 3,000 miles on it I took it back to the Dealer the next morning for warranty repair.
Now the good part. Upon arriving at the Dealership Service Department I was asked what i was bringing the vehicle in for. I told him a lifter on the right side of the engine had collapsed. He looked at me like I had three heads and grunted.
I left the vehicle and after not hearing anything for two days I called the Service Department. I got the reply of we are looking at the vehicle and trying to determine where the noise is coming from. I told the person a lifter on the right side of the engine has collapsed, again I got a grunt. Long story short I would call ever two days for a week and a half and get the same answer. Having enough of that I asked to speak to the manager. I asked him to provide me with a definitive date my vehicle would be ready and told him that I had also called Chevrolet and asked for the vehicle to be transferred to the other Chevrolet Dealership in town for the warranty repairs.
He advised he was going to check into the problem. The next morning he called back and advised he had great news. He advised the service department had finally determined what the noise was. A lifer on the right side of the engine had collapsed. I asked him to read off of the warranty repair request I made when presenting the vehicle for service. He said, d**n lifter on right side collapsed and hung up.
I called Chevrolet again. A area representative called me back in about thirty minutes and advised he was in route to the dealership and my vehicle would be ready for pickup by 3 pm. At 3pm when I went to pick the vehicle up everyone was apologetic. I told them I was not in the mood to hear it, retrieved my vehicle and left.
I traded the vehicle two years later after having other problems with it and always wondered if the problems being experienced were sleeper problems left by the Dealer Service Department for me to experience on some dark rainy cold night.
   / Oil coming from valve cover breather #16
Like mentioned above = false
   / Oil coming from valve cover breather #17
As for the oil coming out the breather tube, I had the same problem in my old Massey ferguson backhoe with a Perkins. I pulled the valve cover and found a small bolt had come out of the top of the pressurized rocker shaft right above the oil supply tube. Shooting 50 psi of oil straight up and right next to the breather.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
