Oil & Fuel Oil coming from valve cover breather
   / Oil coming from valve cover breather #1
Reddogs
Gold Member
John Deere 790 / Kubota L3301
I finished putting on my backhoe on my John Deere 790 and fixing or replacing the hydraulic hoses that were leaking, and when I cranked it up to test, all of a sudden a rush of oil came out of the hose from the valve cover breather. I always had it vent out and drip a little but never stream out like a faucet, and it left a stream of oil from the barn to the road and back to the driveway where I parked to check it. I checked the breather vent metal screen and reset it and checked the oil level and it seemed fine and the oil is clean, but now its shooting out oil and puddling under the tractor as soon as I crank. Everything sounds and drives normal, and power is fine but dont like it loosing so much oil like that. I'm going to open the engine up, what should I check or look for?
   / Oil coming from valve cover breather #2
When was the last time the Yanmar engine filter was changed? Ag machines need the tallest possible filter without getting touched by other working hardware on the machine and the filtration micros no lower than 24 microns. The finer the filtration, the faster the filter will clog up.
With that said, IF the oil filter has not a by-pass valve, you could see blow-out just like the JD790 event now.
These Yanmar engines are made to JIS standards and not SAE, best oil to use is 10W30 diesel Rotella T4 or Quaker State or Valvoline equals.
15W40 is too thick and will trap heat in the engine longer. JIS standards for oil passage ways are narrower for engines too. So, 10W30 summer and 5W30 winter.
   / Oil coming from valve cover breather #3
Sounds to me like the drain back passages in the head are clogged with sludge. How many hours, what oil are you using and how often to you change it?
Thats what I am thinking....I had the oil change a few months ago, then changed a few weeks ago with 15w40.
Just changed it, but not sure what you mean by ''tallest", got standard one from dealer.
   / Oil coming from valve cover breather #6
Not a plug for Archoil but I use their Nano-Borate additive in my engines constantly (it ain't cheap). The interior of all my diesels and gas engines are clean and free from any sludge or build up. No bronze tint on anything either which is typical from using multi grade synthetic oils.
   / Oil coming from valve cover breather #7
Hey 5030, what is the "bronze tint" you speak of due to using multigrade synthetic oils? I ask because I was thinking of switching to shell synthetic 5w40.
   / Oil coming from valve cover breather #8
Check your hydraulic fluid level. Sounds like something was changed and hydraulic fluid is being forced into the engine.
   / Oil coming from valve cover breather #9
Short and stubby filter vs tall filter in height. That is all.
Yanmar engines will work better and last longer on 10W30. We've hit this topic so much in both the compact Deere sub-forum and the Yanmar sub-forum over the years here and elsewhere.
   / Oil coming from valve cover breather #10
Not 5030 but, here is more than you ever wanted to know about automotive oil.
2015 Ram 5500 IMT 3203i 4,000lb 2 Ton Crane Service Truck (A55852)
2015 Ram 5500 IMT...
ALLISON TRANSMISSION (A55745)
ALLISON...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
JOHN DEERE 318G SKID STEER (A52707)
JOHN DEERE 318G...
