Oil & Fuel Oil changes for LB 1914
/ Oil changes for LB 1914 #1
hz293
Kalama,WA
Kubota B7510HSD
I've got a Kioti LB1914 with a loader. I want to change the hydraulic oil and engine oil. Under the seat there is a opening that says oil but it has no dipstick. I don't see oil in it. so here's the questions.
Is there a sight glass or dipstick to tell me if it's down?
How much oil does the hydraulic system hold and what viscosity?
I see 2 bolts under the tractor below the seat. Are these both drain holes?
Do I fill the oil through the the hole marked Oil or is there anothe spot to fill?
Any info would be appreciated.
Harris
/ Oil changes for LB 1914 #2
Sight glass for hydraulic system is on the right side of the transmission close to the brake pedals.
25.4 US Qts of Multi-grade Transmission Fluid
Most likely, but owners manual indicates 5 drain plugs.
Do I fill the oil through the the hole marked Oil or is there another spot to fill?
Yes, added to the red fill port on top of transmission.
