oil change
/ oil change #1
K man
Platinum Member
Quadeville, ont
2014 Kioti CK 30 HST with cab. 2018 Cub Cadet Challenger 750 EPS UTV
I am going to do my own oil change and I am a bit confused to where to pour the new oil into the engine without getting it into the valve area.
The reason why I am asking is that I read somewhere a while back about not using the top opening on the valve covers for pouring oil in as it would leak into the top of the head and valves.
Please do not insult me just want to make sure that I am doing it right. I usually get the dealer to do all my service but because of the Pandamic crisis I have to do it myself.
Any input would be great
Thanks
Gilles
/ oil change #2
I think you're on the right track, and I don't see why it would hurt to pour new oil into the proper fill location. The oil fill port should be in the valve cover, on the top of the engine right above the dipstick.
If it helps, I don't know of any other way to get oil into the engine....unless someone has come up with some odd way to fill it through the dipstick tube.
/ oil change #3
Use the proper oil fill location indicated in your manual, the dealer will also use that same oil filling location. Make sure you fully drained the old oil, and replace the drain plug but don't over tighten it, change the oil filter and tighten the new filter to hand tite only.
You need 1.53 gallons or 6 quarts+filter and when your all done, check for proper oil fill on the dip stick. So you start with 7 quarts, but only add 6.25 quarts. Screenshot_20200428-074624_Xodo%20Docs-picsay.jpg
/ oil change
Thanks guys,
I was sure it had to go on top of the engine just like a car, the only other place to put the oil would be hole for the dipstick which is not very wide.
Thanks
Gilles
/ oil change #5
After filling with new oil, wait a few minutes for the oil to drain from the top end of the engine to the oil pan. I think you’ll enjoy the project and will be doing your own services from now on.
/ oil change
Thank you all appreciate your feed back :thumbsup:
/ oil change #7
Kman, if you fill through the valve cover pour very slowly. It is possible to fill the valve cover faster than it drains down to the sump. The oil can travel through the breather hose to the intake and fill up any cylinder that has its intake valve open.
There is another oil fill at the orange cap near the injector pump. Blue circle in pic.
/ oil change #8
Good catch! Yes, if there is a side oil fill, by all means use that one.
/ oil change
That is exactly what I had read about oil traveling though the breather hole.
Thanks
/ oil change #10
Amvcane: Good catch indeed.
My CK4010 has the upper oil inlet on the valve cover permanently secured now and capped by the factory, and my proper oil inlet is now plainly marked on the inlet nearest the dip stick. So that service manual picture is marked wrong for the newer tractors.
/ oil change #11
My book does not show the top option it shows the side only - I believe the top is sealed....
/ oil change #12
On my Kubota M6040 there is only the low fill port as AMvCane has shown.
Be safe - fill thru this lower port.
I have a metal funnel with extended flex nozzle. Temporarily wire it up to an arm on the FEL. 12 quarts - simple as pie.
/ oil change #13
Thanks
Gilles
Most vehicles have the oil refill on the valve cover. See no reason not to use that spot. On our JDs, there's another one that drains it directly to the sump/pan, but it is canted and is more prone to spill if poured slightly too fast.
Why do we think tractors are so much different from other engines? Crap. Use common sense.
Ralph
/ oil change #14
I changed mine a few days ago. I used a funnel with a small outlet and just poured the 5 liters straight in the rocker cover. It's the way I always do it. No problems.
Mine is 2006. The later ones had a oil filler neck down the side of the block.
/ oil change
Bring you up to date. I had the dealer come service my tractor and he showed me the spot to fill the oil in by the dipstick with a big orange cap lol. Now I know for sure where to put the oil next time I will do it myself.
Thanks all
Gilles
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2015 Chrysler 300 Sedan (A61574)
2015 Chrysler 300...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
John Deere 50 (A60462)
