Oil change type and hour questions
   / Oil change type and hour questions #1
bigrich954rr
oregon
branson 4720h 6ft brush hog ,post hole digger, ripper, pallet forks,
I have a Branson 4720H I changed engine oil and filter. Also Trans oil and filter at 50 hrs with Branson hydraulic oil and T6 15-40 oil
Was I suppose to just change filters at 50 ?
How many hours should I change oils at ?
How long do you run your oil or hyd fluid ?
   / Oil change type and hour questions #2
Engine oils I change around 50 hours or every two years, whichever comes first. Hydraulic oil is recommended at 250 hour increments if I recall
I always change filters when changing fluids.
Don’t forget your air and fuel filters. Check your air filters regularly for varmits chewing them up
Thank you what I was looking at is different then the pdf which makes more sense to me
   / Oil change type and hour questions #5
Owners manual states changing both at 50 and the reason is to flush out any manufacturing scraps/filings and such that may have remained in the system. The manual also shows the recommended change interval and I never change oil with an old filter as you don't know how clogged it is from the old oil.....possibly activating the bypass valve in the filter, and it usually contains a quantity of used oil.
The owner's manual is for "The World's" users and I don't stress my equipment all that much. I decide when to change my fluids.
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
