Oil change intervals
/ Oil change intervals #21
I own a 2009 accord that the prior owners must have gone by the oil change monitor. It calculates engine load and miles for the oil life percent. Well with 106k miles it was burning 2qts of oil in 1,000mi. I switched the oil to rotella t6 and changed it every 1,000mi for about 8 oil changes. It's now gor 150k and dosnt use 1/4 of a quart in 3kmi. Change your oil often.
/ Oil change intervals #22
Believe it or not! I stopped in at a gas station and the
guy said take a look at this! He had a coffee can it looked
like a liquid but didn't move. He said a guy drove his pickup
in and wanted an oil change he was having lunch so he
would change his oil after lunch put the truck on the rack
removed the drain plug nothing came out so down with the
rack started and warmed up the engine up on the rack and
removed the drain plug and its in the can! You can turn the
can upside down nothing comes out bu;t it was in his truck.
Wonder how he got his truck to start in the winter? That
stuff is worse than sludge it don't move!
I will be using Mobil 1 as no warranty it died last year
will change between 7 to 10k I have know people that
change every 25k with no problems
If you don't change the filter don't bother to change the oil
willy
/ Oil change intervals #23
10,000 miles or one year with Mobil 1 synthetic and Mobil 1 oil filter.
/ Oil change intervals #24
A good synthetic oil will not cause issues going by the oil change monitor.
/ Oil change intervals #25
My issue with synthetics is the will impart a bronze varnish on internal parts of change intervals are extended too long, but then I use Nano-Borate additive so my engines inside never 'bronze' up.
/ Oil change intervals #26
willy
lol -- That reminds me of when I was a kid working in a service station. Girl brought in a 68 Firebird for its first oil change in 1978 because her dad was nagging her about it. When I pulled the drain plug, nothing came out. moved a screwdriver around in the drain hole & got some sludge to drain out along with pieces of the fiber they used on the timing chain sprocket. Told her it needed to be opened up so I could replace the sprocket. She didn't want to spend the money & said just do the oil change. After the oil drained & was changed, the oil pump wouldn't prime so no oil pressure. Her Dad came down to make sure we weren't taking advantage of his daughter ... then I showed him the chunks & residual grease like substance in the drain pan filter. Ended up needing a new oil pump, new timing chain & sprocket and a new water pump to drive off so he could trade it in for his baby girl's next car. I'm guessing the next owner needed a full rebuild because when I cleaned up the pan, I found metal shavings everywhere so the bearings were toast if not the shafts.
Better story was a guy drove up to the full service pumps & asked me to check his oil ... (wife's car was the story). Nothing registered on the stick & I wound up putting 4 1/2 quarts into an engine designed to hold 5 quarts before it showed full. I told him that for another five bucks I'd put him on the rack & change his filter as well. He just drove off after paying for the gas & oil.
/ Oil change intervals #27
As crazy as some of these stories sound, I have no doubt this happens more often than you think. I have drilled it into my kids, as my dad did me, about how important oil changes are and I still had to remind my boys to do it or have it done.
They finally started having it done but usually won't do it themselves. Fine, just get it done. I pay to have mine done now to.
However, I'm seriously entertaining buying a lift for the barn and if I do, I will be doing my own changes again. I'm tired of paying for crappy service at these places. I just don't like climbing under cars anymore.
/ Oil change intervals #28
Buy the lift, my only regret - not buying it sooner. I have a 4 post BendPak 9000xw. When not in use my ZTR sits on it, saved me from putting up another garage....
/ Oil change intervals #29
Anyone do a valve job with the stick with a suction
cup on it? I did a valve job on my dad's 48 Pontiac
Rub your hands on the stick/handle like your trying to
start a fire
When over to a friends house he was going to overhaul
his engine think it was a chevy V8 all I can remember he
had the engine on a hoist and was under neath it taking
off the oil pan but he for got to drain the oil first and got
his oil bath.
willy
/ Oil change intervals #31
Maybe the guy that didn’t want to spend money on a new filter figured that the old one was still good since there was basically no oil running through it……
/ Oil change intervals #32
start a fire
his oil bath.
willy
Done that stick and suction cup thing. Did it on a couple engines that I overhauled.
/ Oil change intervals #33
One thing I never do is go to one of those 10 minute oil change places,, oil changes and filters are done right here. Those oil change emporiums are staffed by basically incompetent employees but even worse you have no idea what they are putting in your crankcase far as oil is concerned and never, never have your slush box flushed either.
/ Oil change intervals #34
People forget that as someone mentioned severe duty. Driving the car 5 miles in Atlanta to work is not as hard on oil as driving 5 miles to work in Cleveland Ohio. Not sure how many miles are on my car. I have a good idea though. The odometer stopped counting at 1 million kilometers. That is about 621,000 miles. A year later and still reading 621,000 miles. I drive about 33,000 miles a year so I change the oil every 4 months. Easy on oil driving where work is usually 44 miles one way. Oil gets warm enough with a long drive. Living where it is warm my vehicles do not suffer October to April cold weather. 10,000 mile oil changes with Mobil 1 diesel synthetic as recommended by the manufacturer has worked for me. Head never been off the engine. Still gets good mileage. Drinking oil like crazy. It uses at least a half quart between oil changes. Maybe closer to a quart. Still gets 50 mpg during the 60 degree season where there is no need for AC. AC kills the mileage knocking off up to 5 mpg or 10%.
I have done oil analysis when the engine was low mileage (100,000 miles). Reports came back high silicone like possible leaking air filter. Half a million miles later and it still runs well. Lots of air filter changes, fuel filter changes and timing belts and water pumps every 100,000 miles. I am still a fan of oil analysis. I should do one one in 3 months to see what it reports.
Wasn't BMW kind of forced to offer free oil changes because people who lease their cars turn them in after the lease is never having changed the oil?
/ Oil change intervals #35
As a rule I go by the oil change monitor. I usually change it when they get near 10%. I also don’t like to go much over a year before I change the oil in something. I use full synthetic in everything, car, truck, tractor, small engines.
/ Oil change intervals #36
We are the original owners of my wife's car, a Toyota, and 10,000 is the recommended change interval. I have changed the oil myself with a quality synthetic of the recommended grade every 10,000 miles. The car is now at 173,000 miles. Never an issue, runs great. If I can remember, perhaps I was skeptical too, but after 10 years and 17 changes, 10,000 is just standard procedure (for this vehicle).
  • Good Post
Reactions: JJT
/ Oil change intervals #37
Simple…just tell them that you want your free oil change every 5k miles. If they say no…then walk out. Give it a day and they will be calling you. Also, your first oil change should be around 1500 miles…lotsa wear in material and leftover factory shavings in the block
/ Oil change intervals #38
VW has been doing this for more than a decade on whole fleets. They use the Amsoil-like stuff (slightly higher ranking than Mobil-1)
I have a Touareg. 10,000 miles recommended. Many, many of these on the road, and it has/had 10 year warranty on the engine as well.
I used Mobil-1 and then Mobil-1 extended on my '98 Subaru Forester after the first 8 years or so. Got more than 200k miles on it before it succumbed to body rust this year. The engine was fine. 10k changes and filter at the same time. The engine probably would have gone at least another 250K had the there not been body rust at the wheel well. I added a little Lucas from time to time in the last few years.
JJT also had an excellent empirical, data-driven post.
Yes, synthetic oil is better, and better by a big margin. Study after study has shown this, and major manufacturers have confirmed it and stand by it enough to give longer warranties on their vehicle engines. If manufacturers trust their entire fleets and are willing to standby it to a very large extent, it should give anybody comfort.
/ Oil change intervals #39
Im getting a new Tacoma and this will be my first vehicle that uses full synthetic oil. They will change the oil every 10,000 miles for three years. But it’s hard to imagine going 10,000 miles on oil even though it’s synthetic. I’m old school and my thinking is I could change it at 5,000 and then they change it at 10,000 etc. Then after the three years of free oil changes I would then change it every, say 7,000. Is my thinking wrong?
Wrong site. No disrespect but this is a tractor site...
/ Oil change intervals #40
I drove my VW Beetle from New Hampshire to California in 1966. Many or most cars in those years had no oil filter. When I visited a pal in New Orleans, I emptied all my belongings into his apartment and got the oil changed. Didn't dare go the whole 3K miles without a service!
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2012 Ford F250 Service Truck 4X4 (A64047)
2012 Ford F250...
2012 VOLVO VNL64T630 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2012 VOLVO...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
